10-26-2013, 08:51 PM   #1
old4570's Avatar
K10 Question ...
Hmmm , Im just wondering what the file size on a K10 might be in JPG mode ?
Mine seem to be under 2MB ???
And only slightly larger than on my K100D ...
My K20D pushes close to 9MB , is it just the differences in Generation ( Model / sensor - stuff like that ? )
10-26-2013, 08:55 PM   #2
It depends on the file quality and what you're shooting. 2mb to 3mv would probably be normal.
10-26-2013, 11:36 PM   #3
PJ1
PJ1's Avatar
My K10D jpegs are 2.4 to 3.8 MB depending on the content (converted in camera to jpeg). I don't know how they would go as RAW converted to jpeg
10-27-2013, 04:16 AM   #4
old4570's Avatar
I just checked , my K200D produced images around 3.5 to 3.8 MB ...
So the K10 is producing images half the size ... Does that mean they are 6.1 MP images ... ? rather than 10.2 MP
10-27-2013, 05:24 AM   #5
bluestringer's Avatar
You need to go into the file format menu and set the recorded pixels and JPEG quality settings higher. Sounds like they are set on the lowest setting.
10-27-2013, 05:57 AM   #6
old4570's Avatar
Hmmmm
QuoteOriginally posted by bluestringer Quote
Thats what I thought , but they are as high as they will go : 3 Stars ... ( 1.31 Firmware )
10-27-2013, 06:39 AM   #7
Remember pixel size and file size are two different things. With my K10, I shoot in RAW and my DNG files are all around 10MP. If I convert without any resizing or anything they come out as around 2-3MB JPG files.
10-27-2013, 07:13 AM   #8
paulh's Avatar
QuoteOriginally posted by old4570 Quote
3 stars is the jpeg quality setting. You can set the megapixels to 2, 6, or 10 megapixels. It sounds as though you may have it set to 6.
10-27-2013, 07:28 AM   #9
old4570's Avatar
Nope
set to 10MP and ***
In RAW mode they get over 3MB but not over 4MB ... Its strange ... I even set the camera to return everything to default values , and then went over the settings ..
Even re flashed the firmware .. with a freshly downloaded 1.31
Is 1.30 Firmware available some where ?
Is there software available to tell me if the file is 10MP ? ( Very strange )
10-27-2013, 07:46 AM   #10
builttospill's Avatar
Yes, you can tell if it's 10MP by the dimensions of the JPG picture. They should be 3872 x 2592.
Also, your subject makes a huge difference on file size. If you're shooting a white wall, your file is going to be about 1 MB, if you're shooting a scene with lots of color and light differences, your file might be over 4 MB with the K10D.
10-27-2013, 08:35 AM   #11
set to 10MP and ***
Just about all PP software will tell you the pixel size. I use FastStone, it's free and works great for PP raw files and converting them to JPG. Mine all show as being a little over 10MP. I think you are fine, as others have said, the content of the photo will cause different JPG sizes. Mine run from about 2-3MB after conversion, resizing will get them even smaller.
10-28-2013, 01:43 AM   #12
PJ1
PJ1's Avatar
Exactly. I thought my K10D jpegs were a bit light on until I did the research. the 10MP sensor is giving roughly 2.4-3.8 MB jpegs and the 16 MP sensor on the K-01 is giving me 6.5-7.5 MB jpegs (a slightly better jpeg to RAW file size ratio). I don't know whether the jpeg conversion for the K10D is a bit more brutal (?) or if this related to it being a CCD sensor but I have no issues with the images from either body.
10-28-2013, 02:05 AM   #13
old4570's Avatar
Thanks guys ... Just that I was used to the k20 and K5
10-28-2013, 08:39 AM   #14
Give the firmware upgrade some thought before actually doing the deed. v1.20 might be the better solution since it does not support SDM.
10-29-2013, 01:56 PM   #15
I have firmware version 1.31 on my K10D. I have no problems with it. Upgrading from 1.30 to 1.31 made no noticeable difference in file sizes.
I normally shoot RAW (PEF) + JPEG. The RAW files are usually around 12-13MB and the JPEG's are 2.5-3MB. I shoot everything in 10MP resolution, three star quality. It works out nicely, as the combined size is almost always right around 16MB, which makes capacity calculations for memory cards easy. I get roughly 250 images on a 4GB card.
k10, pentax help
jumping from K10, auto focus question slip Pentax DSLR Discussion 6 11-03-2012 05:06 PM
K10 Setting Question Deiberson Troubleshooting and Beginner Help 7 01-25-2011 10:34 AM
K10 Horror Repair Question voicelit Pentax DSLR Discussion 14 06-15-2010 03:32 PM
K10/20D owners question jamesm007 Pentax DSLR Discussion 7 06-10-2010 11:13 AM
K10 autofocus question Hornet Pentax DSLR Discussion 14 09-20-2007 01:20 PM
All times are GMT -7. The time now is 12:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
