10-29-2013, 09:59 AM   #1
help needed - can't mount lens
today i recieved a lens that i bought online , a Soligor 35-80mm macro zoom , it is with a P/K mount , it is written on the lens
now i cannot mount it on my Pentax K-5 , anybody can advise me ?
thnx, Hans
10-29-2013, 10:17 AM   #2
here are the pictures of the lens
PENTAX K-5  Photo
PENTAX K-5  Photo
10-29-2013, 10:44 AM   #3
Hi,
The problems is the flange on some K mount lenses. It could be cut off without affecting the lens or mount. This post will help with this type of lens surgery.
https://www.pentaxforums.com/forums/120-general-technical-troubleshooting/140...ml#post1464398
Good luck with it and enjoy the lens.
Best regards,
Yuriy
10-29-2013, 10:54 AM   #4
Thnx Yuriy ,
i think this can be the solution , i will try it out , but i find it strange that everywhere you read that the lenses are compatible with all k-mount , because mine i cannot mount it on my camera body
10-29-2013, 11:21 AM - 1 Like   #5
QuoteOriginally posted by Hans V Quote
Thnx Yuriy ,
It is true when talking about Pentax branded lenses with the exception of one rare lens, the 35-70 autofocus lens that came with the ME-F. However, third party manufacturers did nonstandard things like this, it wasn't an issue at the time but caused an issue with cameras with PZ/SDM contacts later on. Same with the Ricoh pin found in many older lenses, at the time it was completely compatible with K mounts, but when Pentax added screwdrive autofocus the pin could get stuck.
10-29-2013, 11:31 AM   #6
it's my first lens who gives problems , perhaps i was lucky until nnow , lol
10-29-2013, 11:40 AM   #7
Could have been worse, your first experience could have been the Ricoh pin, your lens could be stuck half mounted on the camera with no easy way to get it back off. theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
These are the only two problems you should run into as far as compatibility with third party stuff.
10-29-2013, 12:23 PM   #8
bluestringer's Avatar
There's two or three screws holding that flange on, just remove them and throw the flange away. I had to do that with one I had.
10-29-2013, 12:27 PM   #9
QuoteOriginally posted by bluestringer Quote
Same thing, except I would save it in case you wanted to resell it someday.
10-29-2013, 11:32 PM   #10
QuoteOriginally posted by elliott Quote
ooo then i need to be carefull , because i bought on ebay one old ricoh with 2 lenses , thnx for the information , i will be carefull
11-01-2013, 01:41 PM   #11
There are a few others with certain M-42 lenses and accessories (bellows and such). The typical issues are mirror clearance, focus ring clearance (e.g. Helios 44-3 58/2), and various protrusions present on lenses designed to work with special features on other brand cameras.
lens, pentax help
Help with T-mount (I think!) 500mm mirror lens Edgar_in_Indy Pentax SLR Lens Discussion 5 07-10-2012 07:40 AM
Why I don't sell on ebay...technical lens help needed! irishwhite Pentax SLR Lens Discussion 24 03-11-2011 03:52 PM
Why can't I get this lens to mount? Julie Troubleshooting and Beginner Help 18 02-01-2011 08:59 AM
Help: can't get lens to mount on new K100D Super Snicky Pentax SLR Lens Discussion 5 07-17-2009 08:03 PM
Help - can't remove lens from my K2000 CSSLDR Pentax SLR Lens Discussion 13 04-13-2009 06:57 AM
All times are GMT -7. The time now is 02:35 AM. | See also: NikonForums.com, part of our network of photo forums!
