11-01-2013, 04:27 PM   #1
Replacing hotshoe on AF500ftz
I thought there be an old thread on this, but can't find the relevant one to this model -
How do you get the shoe housing out of the metal cradle?
I got a replacement shoe from USCamera, and opened the housing, but the metal cradle is still firmly attached to the front 1/2 of the housing with no obvious way to remove it. Anyone btdt?
Thanks!
11-01-2013, 07:07 PM   #2
Well, if there is no obvious way how it is attached, my guess is that itīs glued. If so, i would carefully start heating the metal part. Not too much so the plastic doesnīt melt.
11-01-2013, 07:19 PM   #3
Oro
Thank you.
I found it. I'll mention it and few other things for others in the future; I couldn't find another thread relevant to the AF500 by searching.
There are three long thin screws through the metal plate from the top, into the hotshoe. Awkward to see and get at. Once I took a brief break and came back, it was clear.
before reinstalling the new unit, I recommend chasing the threads of the new hotshoe with the screws before assembling it. Mine had a lot of plastic flash in it and were really hard to screw in in place. I disassembled it and did that, then it went together much better.
Note the lock ring is directional top/bottom - it will screw in upside down, but then won't lock down. The curved bottom of the thumb tab is towards the bottom.
Also, take out only the four screws (2 top, 2 bottom) on the BACK half of the case. The front ones hold a stabilizing bar in place and don't do anything towards disassembly.
Be careful routing the wires to the swivel flash head when reassembling. It is easy to kink them then pinch or sever one when rotating it. If it has the slightest resistance when you try to swivel it once back together, stop, disassemble, and try again. Guess how I figured that one out.
And, Importantly, say to yourself:
I will never transport my camera with the flash unit attached again.
11-01-2013, 10:14 PM   #4
Good to hear you found the way!
cradle, metal, pentax help, shoe
GPS on your hotshoe gokenin Pentax Camera and Field Accessories 22 09-01-2013 08:07 PM
How to transplant hotshoe on K1000? travfar Pentax Film SLR Discussion 12 06-06-2013 08:26 PM
Loose hotshoe on K5 GvilleRick Troubleshooting and Beginner Help 2 06-30-2012 04:43 PM
Advice on Replacing the Lens Mount on a DSLR? Julie Pentax DSLR Discussion 16 02-23-2012 10:02 PM
Broken Plastic Hotshoe on Flash Trigger. Suggestions? reivax Flashes, Lighting, and Studio 7 01-31-2012 09:46 PM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
