11-05-2013, 10:22 AM   #1
K10D connectivity issue with win7
Hello everyone,
Im having troubles with connecting my K10D camera with my laptop (OS Windows 7). It appears to me that this is due to the missing USB drivers, but Im not sure. The problem is that I cant find them anywhere (ones that are suitable for Win 7) and I read several articles that said it is not neccessary to install USB drivers for Win 7. So if you happen to know where I could either get them or how to solve this problem I would be glad
(Note: I need to connect my camera in order to use remote control program (PK Tether), not to transfer pictures)
11-05-2013, 11:18 AM   #2
bluestringer's Avatar
Update your USB drivers from your laptop makers website.
11-05-2013, 04:35 PM   #3
Otis Memorial Pentaxian
I have a K10D and a Windows 7 laptop that I had never connected to so I just went downstairs to give it a try. It worked, no problem. Here is what I did:
  1. Boot the computer and login using an account with administrator privileges
  2. With the camera off, attach the camera to the computer with the USB cable
  3. Turn the camera on. The computer should indicate that it is installing the device drivers. No download, no drama. Once installed, it should ask you what to do next.
  4. You should be able to connect from all accounts (not just admin) from then on
There is nothing particularly special about the USB drivers. The camera identifies as a generic bulk storage device. As for remote tether over USB with the K10D using pk tether...that may require more than the standard bulks storage drivers. Have you installed the .NET framework (v3.5 or better)? You might want to contact the author. #tkos is a member here, though not very active.
camera, drivers, k10d, pentax help, usb
K5 iis - Compatibility issue with Yongnuo 560 or hotshoe issue? maxk7dish Pentax K-5 & K-5 II 2 10-02-2013 06:43 PM
Pentax to iPad connectivity _Bergman_ Pentax K-30 & K-50 24 08-24-2013 10:10 AM
Manual focus issue with K10D Tall Guy Pentax DSLR Discussion 24 04-28-2010 03:04 AM
issue with firmware updating k10d mfc Pentax DSLR Discussion 7 01-19-2008 10:26 PM
Test of the K10D exposure issue with M lenses Dana G Pentax DSLR Discussion 14 03-22-2007 11:20 AM
All times are GMT -7. The time now is 07:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
