Originally posted by swcgrtra
Ripit, Thank you so much! You solved it. I had already thought of the aperture ringsetting on the lens itself, and checked that to no avail. One of my lenses doesn't even have a manual aperture ring. But I was unaware of the "allow use of aperture..." setting on the custom settings of the camera. I set that, and it works perfectly. I was worried I had screwed the firmware up. I can't thank you enough!
Ok, perhaps you can help me with another question. I just tried to manually set the aperture on my Tamron Aspherical AF 28-80 (non digital) lens, and it makes the camera automatically go into MF mode...is that normal or a setting issue?
