11-12-2013, 09:15 PM   #1
Newbie Questions
I just made the jump to dslr 2 weeks ago with the purchase of a K-50 w/18-135. Since I've shot only slide film for the last 36 years and mostly using my PZ-1 for the last 22 years this has really been a challenge for a 71 year old. I Have some questions and yes I have read the manual 4 times.
I'm having a hard time just figuring out what exposure mode to use. I used AV mode in my Pentax ME and have primarly used Hyper Program in my PZ-1. My questions are:
Why choose AV or TV over P when you can adjust both(Hyper Mode) depending your need to comtrol DOF or subject motion?
Other than in Manual mode is the only over/under exposure indicator the need for flash?
What is the TAV mode all about. I've played with it and sometime it will expose correctly but far more often than not it will over expose 4 or 5 stops and I see no indicator in the viewfinder of the exposure error.
By the way I only use the viewfinder.
Last question for now, How long can I expect a fully charged uninstalled battery to hold a useful charge?
Thanks for any quidance you can give me.
11-12-2013, 09:29 PM   #2
QuoteOriginally posted by LOU16 Quote
There isn't much of a reason unless you want to be locked into either mode such that the other e-dial is disabled or serves another function.
TAv just means auto ISO with manual shutter speed and aperture. If the ISO can't go low enough based on your selected settings, you might end up overexposing. If this is the case, the numbers will flash in the viewfinder.
11-12-2013, 10:54 PM   #3
TAV is useful when I'm doing action shots, because either too small an aperture or too slow a shutter speed can ruing my pictures. But most of the rest of the time I just use AV, keep an eye on the shutter speed, and adjust the ISO manually as needed.
11-13-2013, 09:35 AM   #4
I figured out my problem with the TAV mode. I had assumed it would only meter when I pressed the shutter relesed half way but that just locked the displayed settings which were initially flashing. I'm learning!!
11-13-2013, 11:39 AM   #5
Just1MoreDave's Avatar
I catch myself using Av when it makes no sense at all, trying to make it work with exposure compensation. The modes are designed to adjust the camera to you, so no mode is perfect for everyone. Except don't use green mode.
11-13-2013, 12:44 PM   #6
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
QuoteOriginally posted by Just1MoreDave Quote
Sorry, in a word - bull. The green mode is no different than any other mode in that you need to know its strengths and weaknesses. While I use other modes much more than the green mode, I do use it without disappointment - well okay, with no more frequent disappointment with my photos than when I use other modes.
But I agree with the sentiment. If you are going to always let the camera do the driving, you are probably the type that should have saved money and purchased one of the super-zoom hybrid cameras.
11-13-2013, 05:27 PM   #7
FrankC's Avatar
I would suppose that using AV or TV allows the aperture/shutter to be fixed all of the time. However in Hyper mode the aperture/shutter may change depending on how the camera reads the scene. I think it just may be quicker to use Av or Tv and ensure that you're getting the DOF or shutter you want all of the time as opposed to having to turn a dial when things aren't automatically chosen for you.
11-13-2013, 11:49 PM   #8
My experience with my new k50 is if you are using the hyper mode the select AV or TV is locked and the ISO and the other one changes with light conditions.
av, camera, exposure, indicator, mode, pentax help, photography, pz-1, questions, viewfinder
Newbie's K-30 questions... dlarkin_dc Pentax K-30 & K-50 3 06-21-2013 07:49 AM
Pentax 645D newbie questions colonel Pentax Medium Format 18 04-12-2013 04:51 PM
Couple of Newbie questions mcrtex Troubleshooting and Beginner Help 3 02-27-2013 06:44 AM
Few film questions from a newbie.. Louicio Pentax Film SLR Discussion 43 02-11-2013 10:26 PM
Newbie with some potentially dumb questions mothra19 Pentax K-01 13 12-29-2012 01:44 PM
All times are GMT -7. The time now is 05:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
