Originally posted by Chapchalk Is part of my issue because I am use to shooting in jpeg not raw?
The camera has to choose a white balance to create the JPEG file. It's harder to fix it later because of that. The RAW files don't have a fixed white balance and can be changed later. The camera does add its white balance numbers to the file, the color temperature and tint, which are also used to create the preview you see on the camera LCD. But these numbers can be changed to something else.
You might try shooting RAW+JPEG for a while, maybe following suggestions here about setting the white balance in the camera. Then if you get a photo that looks wrong to you, you can open the RAW copy of the file in Photoshop Elements. The program will open Adobe Camera RAW first, and at the top of all the sliders are adjustments for the color temperature. There's an eyedropper tool (top bar, third tool from the left) if your photo has a spot that should be mostly white, gray or mostly black. The eyedropper will choose that spot and adjust the color channels to remove all color tint from that spot. You can move these sliders around and see if it fixes your color problem.
Perfect white balance is not necessary for every photo. I was just reading about the K-3's ability to have two white balances for one image, to harmonize images with multiple light sources. Then I saw this painting, which uses the contrast between light sources:
(That JPG is a really terrible reproduction but is not infringing on anyone's rights and it's good enough to make a point. The colors in the painting are much stronger.)
