Originally posted by RockvilleBob Should the D-LI190 battery be removed when storing your camera for weeks or months? Should they be removed for storage of any duration?
I know chemical batteries need to be removed but I do not know about storage of lithium batteries.
Thanks
I know I am being picky, but LiON is chemistry too.
If you remove the battery, you camera will eventually lose all its customized settings. If that is not important to you, remove the battery.
If you leave the battery installed, in addition to any self-discharge, the camera will be slowly sipping at it to keep its current settings. After a year, you may find the battery had fully discharged so you lost the settings anyhow, AND your battery's life is reduced because a full-discharge isn't good for LiON batteries.
The better option is to take the camera out of storage every month or two and rotate batteries, recharging the one you just removed.Firing a few shots at that time to keep lubricants evenly distributed would be a good idea too.
