11-26-2013, 11:34 AM   #1
Advice Required
Hi,
I am planing to go to a Color Run (that race where people is cover with color dust), and I have seen some comments about problems that happen to most of cameras, I am wondering if taking my weatherproof K5 and a 18-55 WR lens will work, or I should avoid it. Is there any forum member that have covered any of those events with one similar setup? any advice is welcome.
Bumblebee71.
11-26-2013, 11:39 AM   #2
Canada_Rockies's Avatar
Just keep the front of the lens clear whenever you can. I've heard that sometimes the dust is hard to get off the gear, but a quick rinse under a tap should do the trick with Pentax.
11-26-2013, 11:42 AM   #3
Weather sealing won't help much, the color dust is extremely fine and will get right past the seals.
LensRentals.com - How to Ruin Your (or Our) Gear in 5 Minutes (Without Water)
They mention weather sealed lenses, likely Canon L and the higher end Nikon stuff, which should be similar in sealing quality to the DA* Pentax line, which is better than the WR kit lenses.
To have a chance of surviving you should cover it with plastic and zoom as little as possible to avoid dust getting getting sucked in along with the air.
11-26-2013, 12:01 PM   #4
jatrax's Avatar
I would not go near a color run with a camera I expected to be functional after. Sealed or not.
Get a cheap p&s and assume you are going to toss it after.
Just my humble opinion.
11-26-2013, 12:25 PM   #5
LaurenOE's Avatar
Talcum Powder is about 10uM (Micro Meter or Microns) or .0004"
Here are some other dimensions
90% of Wood smoke particles are smaller than 1 micron 0.00004
Bacteria (average) 2uM or 0.00008"
Red Blood Cell 8uM or 0.0003"
White Blood Cell 25uM 0.001"
Human Hair 70uM 0.003"
Grain of Table Salt 100uM 0.004"
Droplets - liquid particles less than 500uM
So if a camera is weather sealed for water, it likely will not stop Talc powder.
11-26-2013, 12:40 PM   #6
TER-OR's Avatar
Water droplet size isn't relevant - it's the water film which matters. That said, fine powders can accumulate in all sorts of recesses and may be drawn via moisture into other areas and cause issues.
11-26-2013, 12:47 PM   #7
Thanks for your quick and wise advices, I think I won't take it, or...would I look too ridiculous if my camera is wearing an under water bag ?
:-D
11-26-2013, 12:54 PM   #8
Won't help your lungs either ! Better stay home and watch it on the TV.
advice, color, pentax help
Abstract Imagination Required WillH Post Your Photos! 7 12-02-2012 08:37 AM
battery voltage required adwb Flashes, Lighting, and Studio 3 06-08-2012 08:06 AM
I've torn a flexible cable - advice required karma mechanic Troubleshooting and Beginner Help 7 11-15-2011 01:30 PM
Some advice required - Birthday Party Shoot roliver Troubleshooting and Beginner Help 5 08-05-2011 07:16 PM
Advice required Naim Khan Pentax SLR Lens Discussion 15 03-25-2010 10:03 AM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, part of our network of photo forums!
