This is using the AF540FGZii, using it's on-board optical trigger. I've had similar results with the AF360FGZ.
Camera settings: 1/100 sec, f/8, ISO 100, on-board flash exposure compensation set to -2.0 EV.
Flash settings: 1/4 power, "S2" dumb slave mode (which is functionally the same as a cheap external trigger -- fires with every flash and does not ignore the pre-flash). The flash is at 90 degrees to camera right.
Using the same flash unit, but in manual mode and with an external optical slave module, did not work, which is what I expected. The external module and/or the hotshoe circuitry is just too slow for the MX-1, but will work fine on a dSLR because of its much slower preflash and mirror flip sequence.
By the way, not sure I understood the previous comments about shooting in manual, but if you meant manual exposure mode on the MX-1's mode dial, note that the camera will still fire the pre-flash. There is no manual control for the on-board flash, just as there is no manual flash control for the on-board flash on the K-5 -- just flash exposure compensation.
