Lenorehig... My original post was given taking into consideration that you stated you are new to Dslr use and you are new to post processing ...Lightroom, Elements, CS6 etc. are great programs and one should eventually be using one of their choice. Still my thoughts are before you try to master two things at once to spend more time learning how to use your magnificent camera then try to master two learning difficult learning curves at the same time. I state that because if your learn your camera and how to properly use the exposures it will put forth then very little post processing should be needed unless you are trying to take the correctly exposed photo to more creative art in nature. Given you are new I still think before you go spend money on software to process you load what came with your camera or whatever is free and try it while you are learning to use your camera. If you feel the need for something else than download the trial versions and try them until you find one your comfortable with then buy it.
Why? Because once you step into the realm of digital post processing just as in film developing there is a lot more that comes into play and learn than just the processing software, especially if your planning to print your photos. Remember this if you have done nothing to your monitor it is mostly lying to you in what corrections you see and have adjusted, the exposure you are seeing isn't what it will print. it will be ok for those photos you upload in srgb for the web sites you upload them to but if your monitor isn't the right type or calibrated and you aren't aren't using the correct color profiles for whatever printer and paper coupled with proofing them then your photo will not print the same as what you are seeing a majority of the time. I will mention this also if you do send any photos out to have them printed, the minute you use the "color corrected" selection then you can throw your post processing out the window.
To be honest sometimes I think its simpler to run down to your local Rite Aide, CVS, Walmart or whatever with your SD card and post process and print right off of it because once it hits your computer processing then the work and fun begins to get it right. Post processing for print, just as it is/was for film developing is an art within itself that takes time, patience and the equipment to learn to do it and have it come out the way you want to have it.
Just my thoughts others may have opposing thoughts and that's fine.
