Originally posted by Julie Maybe obvious, but are camera and lens contacts clean? Sure the lens is locking into the camera right?
Also wouldn't hurt to make sure you have the latest firmware installed.
I had cleaned contacts without alcohol, lens locks fine, firmware is current. Thanks for the suggestions.
Originally posted by Kozlok My Tamron works perfectly on my K30. Suggest cleaning the contacts on the lens with alcohol on a q-tip. Do not pour alcohol on your lens, put a drop on the q-tip and rub it around the contacts.
I did go ahead and clean the camera contacts and the lens contacts with the alcohol, unfortunately no change. Thanks for the suggestions.
