02-10-2014, 08:01 AM   #16
altopiet's Avatar
Are you using Spot focus?
02-10-2014, 08:28 AM   #17
MJSfoto1956's Avatar
QuoteOriginally posted by altopiet Quote
yes, the only choice I have is Spot and nothing else (recall that with the paint removed, I cannot set the AF to anything at all)
M
---------- Post added 02-10-14 at 10:31 AM ----------
EDIT: Do you have enough light reaching the meter?
Do you have the AF/MF switch on the camera set to AF, and to AF-S in menu?
  • This is in bright light.
  • Camera body is set to AF.
  • As stated previously: with the paint removed, I cannot set the AF to anything at all.
Michael
02-10-2014, 10:58 PM   #18
altopiet's Avatar
Michael, I think you should start from scratch with the settings on the camera first, to make sure that's in order...do you have any other old, metal based K mount lens that you can use to ensure the settings are correct and working? Once you are sure it's working then you can add the Nikkor lens, eliminating the camera as the problem.
If the camera is working as it should using CIF, but not with the Nikkor as it is now, then obviously you have a problem with shorting the contacts correctly, and the we can take it from there...
There is another catch. You cannot set AF mode without an AF lens lol. Basically, you need to set up CiF while you have an AF lens (like the kit lens) and then you exchange the lens. If you have a non-AF lens, the AF options box in the Info menu will always be greyed out, so you cannot switch between AF.S and AF.C. But some cameras have a physical switch for this.
I think this is very important....
02-12-2014, 07:22 PM   #19
so I simply attached the old Nikkor directly to the new K-3 (metal to metal) and I get the same behavior: While I can set the focal length, I cannot set the AF. And because I cannot set it to AF-S, there is no possibility of CIF. Ah well. Sad but now I am going to attempt to use Astrotracer with this old Nikkor 180mm. Should be interesting...
Michael
af, beep, camera, cif, focus, lens, light, mode, paint, pentax help, release, shutter, spot, subject
Catch in focus help Halftufish Troubleshooting and Beginner Help 6 03-31-2013 03:27 PM
Catch in Focus and Lens Resolution [k-x] Alec [k-x] Troubleshooting and Beginner Help 20 03-17-2013 12:55 AM
Extension tubes and catch-in-focus GabrielFFontes Pentax K-r 12 12-29-2011 11:24 AM
Catch-in-focus with Tamron Adaptall 2 mirror lens fewayne Pentax DSLR Discussion 14 12-21-2011 10:41 AM
Which lenses support catch-in-focus on K-r? gifthorse Pentax K-r 9 12-08-2011 07:40 PM
All times are GMT -7. The time now is 05:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
