12-01-2013, 04:28 PM   #1
K-x firmware update not loading
Hello Pentaxians,
I have followed the helpful posts on this forum to update the firmware in my K-x. (I am still running 1.00.) After correctly following the instructions-- transferring the .BIN file to the root directory and confirming full battery life-- the firmware update does not load when I turn the camera on while pressing the menu button. I have read and re-read the instructions and tried to re-download and re-install the file. I am using a Mac and a 32GB extreme SD card.
I would be grateful for any suggestions you could provide. I would like to update the firmware and improve the battery indicator on my camera.
Thank you.
12-01-2013, 04:59 PM   #2
mee
Format the SD Card with the Pentax K-x and NOT your computer.. then simply extract and drag over the BIN file.. the file name should read 'Fwdc206b.bin'
if it does not, ensure you actually have the K-x firmware installer and not a firmware installer for another Pentax camera - those won't get read by the K-x
Then take the SD card out of the camera, put it in your computer, drag and drop over the BIN and put it back in your camera.. CONTINUE TO HOLD DOWN THE 'MENU' button and turn on the camera
drag over cursor using the 4-way dial on the back of the K-x to select 'yes' to update..
battery, camera, firmware, k-x, k-x firmware, pentax help
Firmware Update V1.06 for K-5II/K-5IIs Class A Pentax News and Rumors 46 10-27-2013 04:45 PM
K-x firmware update justonecat Troubleshooting and Beginner Help 15 03-23-2011 08:59 PM
Firmware update for K-x and K-7 elg Pentax News and Rumors 26 01-27-2011 01:44 PM
Unable to install firmware update v1.02 on K-x califgrll Pentax DSLR Discussion 10 01-15-2011 09:59 AM
Help with k-x firmware update kiwislice Pentax DSLR Discussion 7 02-25-2010 12:57 PM
All times are GMT -7. The time now is 06:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
