12-07-2013, 06:26 PM   #1
Question on some technical term and its meaning
I am looking at DSLR specifications under "white balance" of 3 brands, Pentax, Canon, Nikon.
Pantax (K-3) say something like ;
Fine Adjustment : Adjustable ±7 steps on A-B axis or G-M axis
Canon (7D)
White Balance Correction: ± up to 9 levels, in 1-step increments
White Balance Bracketing: ± up to 3 levels, in 1-step increments
Nikon ( D800) ;
White balance bracketing : 2 to 9 frames in steps of 1, 2 or 3
Could somebody help me translate them into one unify language?
- Does it mean, K3 has no bracketing? and D800 has no white balance fine adjustment / correction?
- K3 can adjust up to ±7 steps, but 7D can do only +1 step? Then what is ± up to 9 levels of 7D mean?
- what is D800 bracketing mean when translate to 7D language?
thanks
12-07-2013, 07:36 PM   #2
Tom S.'s Avatar
Moved to proper area.
12-07-2013, 09:13 PM   #3
manacho2005's Avatar
I may be a bit off on the translation, but I think it means; Get a K3 and shoot RAW.
12-07-2013, 09:23 PM   #4
Canada_Rockies's Avatar
Pentax K-3 white balance can be set from -7 to +7 A-B [Amber - Blue] and / or G-M [Green - Magenta] axis. The two axes may be combined.
I have a copy of the K-3 manual, and this is the specification. White balance bracketing is unnecessary if one shoots RAW, though.
12-07-2013, 11:04 PM   #5
thank you all the answer so far.
Anyone has a good explanation on my question please let me know.
Note that, My intention is to understand what they, each brands are talking in the specification.
If I were trying to buy a new body, It couldn't be anything else but a K3.
12-08-2013, 02:18 AM   #6
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by manacho2005 Quote
Like your style.
12-08-2013, 07:41 AM   #7
I have none of these cameras, so I could be off, but check out the manuals for fine tuning:
Canon 7d, page 73
http://www.bfm.ee/wp-content/uploads/2011/01/Canon-EOS-7D-Owners-Manual.pdf
Nikon d800, see page 148 (it does have WB Fine Tuning, but I didn't see by how much))
http://www.nikonusa.com/pdf/manuals/dslr/D800_EN.pdf
both explain that "1-step" is a shift of "5 mired", which is a unit that describes changes in colour temperature (the Nikon manual pg 150 explains it a little, or see Mired - Wikipedia, the free encyclopedia, or see Mired Shift Calculator for LEE Lighting Filters for a nice visual calculator). I didn't check what the k-3 means by a 'step', it could be different.
For the bracketing, see page 74 of the Canon manual and page 138 of the Nikon manual. The Nikon only does bracketing on the A-B axis, but gives you many options on what it saves (and it looks like you can go up to 4-steps away from your baseline) and you should see the table in the manual for what they are.
The Canon lets you do bracketing in the A-B or the G-M axis (but not both at the same time) and will save 3 versions of your shot with shifts along the axis you selected of whatever 'step' you selected (1, 2, or 3). In terms of the table in the Nikon manual, the Canon lets you bracket 0/1B/1A or 0/2B/2A or 0/3B/3A or 0/1M/1G or 0/2M/2G or 0/3M/3G
I'm a little puzzled on how WB bracketing can be worth it. Selecting the 'right' one from the back of the camera isn't going to be that awesome and by the time you've loaded your 3 or more jpegs on the computer and picked the 'right' version, you could probably have popped a raw file into your favorite converter and manually selected the WB to your liking. On the other hand, it's a feature that can be freely ignored, should be cheap to implement, and adds more technical mumbo-jumbo to your spec sheet so I'm going to start complaining about the lack of WB bracketing on the k-3.
12-08-2013, 10:43 AM   #8
QuoteOriginally posted by BrianR Quote
[INSERT TONGUE IN CHEEK]Great - another thread about how the K-3 is a super disappointing and useless camera from Ricoh-Pentax. I think Ricoh should retro my K10 firmware to give me WB bracketing, too. [REMOVE TONGUE FROM CHEEK]
After all, the K-3 is only the best APS-C camera out there. Even the fan-boy site reluctantly put the Nikon ahead because of its AF.
12-08-2013, 07:40 PM   #9
Just1MoreDave's Avatar
Canon 7d, page 73
Page 56 of the K-3 English manual says steps of 20 mired units with the front wheel, 100 mired units with the rear wheel. But it's not clear whether these steps are the same as the Fine Tuning steps.
Probably the adjustment range doesn't matter as much as how close the camera comes with its first guess. In other words, you take a shot and see a white balance issue. If Camera A is off by 500K, camera B is off by 1000K and Camera C is 100K, you may be happier with Camera C.
I think my brother's cheapo Canon T3 has WB bracketing.
7d, balance, correction, d800, increments, k3, language, levels, steps
35mm vs. "digital" - a technical/legal question Lex Madera Photographic Industry and Professionals 8 06-03-2012 03:25 AM
Very technical question about in-camera stabilization olenl Pentax DSLR Discussion 29 11-22-2010 02:29 PM
Technical question about sensor density x resolution BBear Photographic Technique 2 07-16-2008 08:36 AM
evening light and its play on subjects... dudlew Post Your Photos! 3 04-16-2008 06:33 PM
Technical Question AmdamJayne Post Your Photos! 7 05-16-2007 12:37 AM
All times are GMT -7. The time now is 11:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
