12-08-2013, 02:42 PM   #1
Temperature Range Of K1000
I just recently bought a Pentax K1000 and I have a question. What temperatures can the Pentax K1000 operate in? I want to take some winter pictures but I do not want to take my camera out until I know whether it will be safe to take it outside during winter or not.
12-08-2013, 02:56 PM   #2
When your camera was new the range of operating temperatures was from 50 C to -20 C. With age, that range might be a bit narrower. There is a whole section of the owner manual detailing operation at low and high temperatures. You can get the manual at:
http://www.pentax-manuals.com/manuals/mf/pentax_k1000_manual_s.pdf
The password is "Pentax".
As noted in the manual, a CLA (Clean, Lubricate, Adjust) to refresh the lubrication may be a good idea.
BTW...Welcome to the Pentax Forums!
12-08-2013, 03:20 PM   #3
Okay. Thank you. I will go check it out.
12-08-2013, 06:03 PM   #4
manacho2005's Avatar
The k1000 is robust, my dad has been using his since the early 80's.
They can work in subfreezing and extremely hot temps since everything is mechanical; the only thing you have to keep in mind is the meter. The meter relies on a battery that can fail in high/low temps.
Have fun shooting!
12-08-2013, 06:33 PM   #5
Separate from the K1000 cold performance is the lens, its ability to stop down completely before shutter actuates.
Most of my -M lenses appear to have a snappy stop down in the cold, but 3 in the collection are sluggish in the cold. Old lube I suppose
They are OK in the summer and OK in winter if warmed up.
12-08-2013, 07:43 PM   #6
Eric Auer's Avatar
If the Camera has been CLA'd with modern lubricants that can deal with a broad range of temps I see no issues.
12-08-2013, 09:08 PM   #7
Canada_Rockies's Avatar
The only time I had a mechanical Pentax not take pictures due to cold was a flight with my brother in law in ambient -30 C. The situation wasn't permanent. I used the camera for another 13 years.
12-09-2013, 06:34 AM   #8
The manual for the S3 (around 1960) indicated that temperatures above 120F or below -55F might affect the shutter performance. Perhaps the light meter in later models is the reason for a more limited range.
12-09-2013, 09:02 AM   #9
That failure was with an original Pentax that I used for a very long time. As near as I can tell it was about 9 years old when I took that flight. I got the impression that the shutter curtains were frozen together, but who knows. The shutters on those old timers ran horizontally and were like rubberized canvas.
camera, k1000, pentax, pentax help, photography, temperature range, temperatures, winter
EXIF data excludes range of focal lengths Schmidt Pentax SLR Lens Discussion 7 08-23-2013 01:04 PM
18-55 lens only has 37mm of range ... spystyle Pentax SLR Lens Discussion 20 07-19-2013 09:42 PM
Dynamic Range of Pentax 16 mp sensor Steven Chain Photographic Technique 11 01-22-2013 04:20 PM
DPReviews dynamic range tests of K-30 are available Docrwm Pentax K-30 & K-50 7 09-08-2012 04:23 AM
Get that monitor off of the default color temperature! slip Digital Processing, Software, and Printing 16 11-30-2006 06:51 PM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
