12-09-2013, 03:49 PM   #1
DA 18-55 WR focuses past infinity?
Greetings
I have a DA 18-55 WR that focuses past infinity. Is it normal? I have two copies of the DAL 18-55 that don't and I was told the optics were the same. Tried some astrophotos and its near impossible to focus to infinity in the dark in the middle of a hay field.
Regards
12-09-2013, 04:05 PM   #2
Yes, this is normal. It can be tough to focus in the dark, sometimes trial and error is the only option.
12-09-2013, 05:37 PM   #3
JimmyDranox's Avatar
It is good that it focus past infinity. I has 2 lens, a kit lens, and a telephoto zoom, that doesn't focus to infinity at all, until I send it to service.
For good focus in astrofoto, I found only one straight way. If your camera has a HDMI output, buy an external monitor, like Liliput, or Feelworld, or better. You will see everything that you can see on the camera monitor, but better, on a bigger screen, and on any direction you want. Of course, must use manual focus, life view with info, to get the magnification up to 10x.
12-10-2013, 07:21 AM   #4
Thanks Adam and JimmyDranox for clearing this issue. The K-30 doesn't have hdmi just usb. Though it seems possible to convert usb to hdmi. I'll look into it. thanks.
12-23-2013, 03:32 PM   #5
emalvick's Avatar
Suggestions:
1. If you are in a spot where there is a road nearby or perhaps some type of farm house, etc, try to focus on some headlights or something else with lights under automatic. Then switch it to manual being careful not to change focus. For that matter you could also use a flashlight to lighten up something that is beyond the hyperfocal distance so that your camera can focus to infinity on that. It isn't too difficult when you are dealing the the wider angle lenses. I seem to recall being able to focus on something on the order of 20-ft (6 m+) away with a lens, which ended up being effectively infinity for that lens. Of course, that depends on the lens, focal length, and aperture.
2. If you can find a few bright stars in the sky, try to focus on them and take a test shot and then lock the focus for the remainder of the shots you want.
Otherwise, it is quite tricky even if you can utilize the suggestions. It's hard to lock a lens focus and move it around without potentially tapping or touching something unintentionally.
12-24-2013, 06:18 AM   #6
Thanks emalvick. Good idea, I'll check during the day the minimum distance at which focus sets to infinity. But this is one instance when quick shift focus is not helping. I have come to think that before taking long exposure I'll check focus with a short 10 s shot. I'll probably move on eventually to a 14 mm 1:2.8 for astro work.
da, da 18-55 wr, infinity, pentax help, wr
For Sale - Sold: WR set DA 18-55 WR and DA 50-200 WR missile Sold Items 6 11-23-2013 05:21 PM
For Sale - Sold: Pentax DA 18-55 WR, DAL 55-300, and DA 18-135 WR lenses Elliot Sold Items 4 11-07-2013 02:46 AM
For Sale - Sold: Pentax DA 50-200 WR and DA 18-55 WR ecruz Sold Items 2 08-27-2013 07:24 AM
Fisheye lens focuses past infinity ChopperCharles Pentax Q 17 07-01-2013 01:03 PM
Spotmatic focuses past infinity? kcobain1992 Pentax Film SLR Discussion 18 02-28-2011 08:26 AM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
