12-12-2013, 01:54 PM   #1
Tamron - F Lens
Does anyone know anything about a lens that was given to me. It is a Tamron-F 1:2.8 135mm
I have tried to find some info on it but have had little luck.
Can it be used with my K-5? Will I need an adapter? I'm assuming it can only be used in a manual setting.
Is is considered to be a good lens?
Thank You for any info you can provide.
12-12-2013, 02:01 PM   #2
jatrax's Avatar
Tamron is a third party lens producer. Meaning they makes lenses for many different types of cameras. It could work on your k-5 or it might be a lens for a Nikon camera. Pictures of the mount and a picture or complete description of the text on the lens would help.
12-12-2013, 02:05 PM   #3
Sorry. Need to clarify. It does have a sticker that says (For Pentax-K) on it.
12-12-2013, 02:08 PM   #4
Should work fine, have you tried to mount it?
12-12-2013, 02:13 PM   #5
QuoteOriginally posted by elliott Quote
No, not yet. I wanted to make sure I wouldn't damage anything. Still learning. Do you know if it is considered to be a good lens?
12-12-2013, 02:22 PM   #6
I have a few Tamron lenses from a similar time, though not a 135mm, I like them. They were one of the better third party manufacturers at the time and their BBAR coatings were pretty good.
12-12-2013, 03:30 PM   #7
jatrax's Avatar
QuoteOriginally posted by mcook Quote
in that case the short answer is yes it will work. One of the nice things about Pentax is that if it's k-mount it will work.
However, there are a few things to be aware of:
  1. Some lenses have an extra pin called a 'Ricoh' pin that can cause problems by getting stuck on the camera. These usually have a KR, K-KR, or K-R type of designation. Seriously doubt this is an issue for you
  2. Some lenses have an extra large aperture lever shield that will not allow the lens to mount on a newer camera with SDM contacts. Again, not likely in your case.
  3. The lens will only have the abilities it had before, so if it is a manual focus lens, it's still manual focus. If it is a manual exposure lens it's still manual
So if you can provide pictures or the complete text then someone can give you a better idea of the capabilities of the lens, but in short: it will work. Put it on and try it out.
camera, info, lens, pentax help, photography
For Sale - Sold: Cosina 55mm f/1.2, Pentax K-7, Tamron 24mm f/2.5, Tamron SP 24-48mm f/3.5-3.8 hinman Sold Items 28 03-28-2014 03:09 PM
For Sale - Sold: Tamron AF 90mm f/2.8 Di SP A/F 1:1 Macro Lens (Model 272EP) steevesj Sold Items 2 06-01-2013 07:36 PM
Tamron 500mm f/8 55BB Mirror lens samples mccarvindh Lens Sample Photo Archive 8 04-14-2012 03:27 AM
For Sale - Sold: Tamron SP AF 28-75 mm f/2.8 and Tamron 90 mm f/2.8 macro lens Vantage-Point Sold Items 5 03-22-2012 03:35 PM
Tamron Lens 28-75 f 2.8 raslgn Pentax K-5 8 03-07-2012 07:29 AM
All times are GMT -7. The time now is 07:57 AM. | See also: NikonForums.com, part of our network of photo forums!
