12-13-2013, 02:42 PM   #1
Artifacts in the photos from K-5
I just noticed strange artifacts when shooting photos against the sun. The parts of the image that are covered by the sun flares have a regular pattern. Other parts of the picture look normally. Is there a problem with the camera or software or I just simply reached its limits? Has anyone seen that before?
The picture is a crop of the affected area.
Shot at f2.4, 1/5000s, ISO400
Pentax 70mm, f/2.4
12-13-2013, 03:29 PM   #2
Stone G.'s Avatar
---- but, isn't this a screen-dump rather than a 100% crop??? You should upload a 100% non-resized crop of the same portion of your image file.
12-13-2013, 05:14 PM   #3
It is a screen dump indeed but it doesn't change the fact that the artifacts are still there and look the same as on 100% crop as attached now.
12-13-2013, 05:30 PM   #4
VisualDarkness's Avatar
What kind of artifacts?
12-13-2013, 05:42 PM   #5
If you were shooting into the sun, you may be seeing a variety of lens related issues, including lens flare and fringing. And if you were using a UV or 'protection' filter on the lens, the problem will likely be worse.
12-13-2013, 05:50 PM   #6
QuoteOriginally posted by Chris74 Quote
Still looks like a screen capture. Are you sure you know how to do a full-resolution crop*? Looking at your original upload, I see some JPEG dithering artifact (introduced in the conversion from RAW to JPEG and possibly related to chromatic aberration), but other than that and low contrast, the image is unremarkable.
* In case you don't...
For in-camera JPEG:
  • Open the original image in a photo editor with size set to 1:1
  • Select a portion of the screen (say 800x800 pixels) with the selection tool and copy the selected area to a new image
  • Save the new image as a JPEG with zero compression and include it in your message here
For RAW:
  • Import the RAW file into Lightroom or similar
  • Make a virtual copy and crop that to 800x800 pixels
  • Export as JPEG with zero compression and include the resulting image in your message here
I would suggest not attaching the file to your message since the forum software is sometimes not kind to attached images. I have found that it works better to upload to Flickr (or similar) and link to the image hosted there.
12-14-2013, 12:20 AM   #7
Don't worry, it's just the NSA watching you
12-14-2013, 11:21 AM   #8
I think we may have offended the OP. He was a new user and appears to have abandoned his thread. Too bad. I was really quite interested in actually seeing the artifacts he was concerned about.
12-14-2013, 11:25 AM   #9
I don't see anyone doing something wrong though.
artifacts, pentax help, photos, picture, sun
Ricoh GR circular rings artifacts in the pictures seyfer Ricoh GR 6 09-05-2013 07:54 AM
A few test photos from the first day with the k-01 robert Pentax K-01 4 11-10-2012 04:10 PM
Pentax could we get the K-5 II / K-5 IIs in color please? Hegemon Pentax DSLR Discussion 17 10-14-2012 01:59 AM
K-5 - Mark in photos when stopped down Codazzle Troubleshooting and Beginner Help 4 05-08-2012 08:08 PM
I feel the dynamic range in video from k-5 is very limited liukaitc Video and Pentax HDSLRs 4 12-29-2011 07:00 AM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
