Originally posted by tr1ckyn1ck Hi
I have a K5 and a 360 flash. This year to take pictures of my kids at Christmas, I would like to set up the flash off camera pointed at the ceiling and trigger it with a radio trigger. I plan to shoot in manual on the camera - the room is quite small, so I don't think the exposure will change much shot to shot.
Could someone please recommend what mode the flash should be set in and how I should go about setting up exposure initially? I still haven't been able to wrap my mind around sync speeds, so I am mostly confused what to do with the shutter speed.
Thanks
I highly recommend shooting in Manual mode for flash photography. There are too many variables that are out of your control otherwise. Try setting the flash manually to full or half power. The more light, the better. But shooting at half power means you can re-cycle the flash faster in case you need to take a few shots in quick succession. Depending on your lens, you might want to shoot something like F/2.8 or F/4. Shutter speed with the radio trigger should be 1/125sec or slower. Technically it can do 1/180 sec, but I've had problems with that in the past where part of the image will be darker because of mis-timing. If you shoot 1/125 sec, the majority of your exposure will come from the flash. If you shoot at a slower shutter speed, aka "drag shutter", you can get more of the exposure to come from the ambient light. So it depends on how you want to balance it. Finally, set your ISO so the exposure looks appropriate. Flash exposure is more complex than available light because now you have a fourth variable. In addition to ISO, shutter speed, and aperture, you also have flash power. But keep in mind that the way you affect exposure are different with flash photography.
Flash power: more flash power gives more exposure to only what is in range of the flash. Far away things are still exposed as if not hit by flash
Shutter speed: faster or slower shutter will only affect the part of the exposure that comes from the ambient light. The contribution from the flash is essentially unaffected.
Aperture: behaves as normal
ISO: behaves as normal
Hope this helps!
