Originally posted by DesertCruiser Thanks lister, but I was hoping for a different answer, the camera probably won't do it. I do have the AE set to spot -- doesn't change a thing. I use manual for most all my night shots of the moon, stars, lightning and fireworks. Good advice, we've been doing this for a long time, never had a LCD that bright. And this is with the very inexpensive 50-200mm DAL lens.
Thanks again,
Don....
That's odd because it works on my K-30. Its some time ago since I last shot the moon with the K-30 so there might be some detail I'm forgetting but for sure it can be done. I used it with a Tamron 18-250 and a Sigma 150-500 which admittedly aren;t very fast lenses but also with a Tamron 90 F2.8 and could always get a a good image on the LCD with the AE adjustment and spot metering.
Have you tried different modes (P, Av, Manual etc) - not for the actual shot but for composing and focusing - I remember that in some modes the LCD did stay too bright despite these adjustments.
@crew1 - that won;t help much - what we need to regulate is the sensitivity of the sensor not the actual brightness of the display - the image is saturated already before being sent to the display.
