Originally posted by Michael Piziak I have not had success switching my camera to Av mode with this lens. In Av mode, it will not let me change the shutter speed with this lens.
This is expected. In Av mode the intent is that the camera chooses the shutter speed based on the aperture chosen by you and the amount of available light. This behavior is dependent on the body being able to control the aperture.
Using Av mode with a non-A contact lens is really sort of a hack. The camera cannot set the aperture (how Av mode is intended to work) and instead operates as if the lens is full open (which it would be for most K-mount lenses). The hack part happens when you use Av mode with lenses having a pre-set or manual aperture mechanism (can be set to be stopped down all the time). Since the lens is already stopped down, the amount of light reaching the meter should be the same as if you used the optical DOF preview in M mode.
The advantage is that you should be able to stop down until you get an acceptable shutter speed...sort of a backwards shutter-priority automation. When it works, it is sort of cool. Unfortunately, it does not work that well. Stop-down metering in Av mode is unreliable at many apertures*. With my M42 lenses (the kind usually used for stop-down metering in Av mode) I can expect as much as 3 stops over-exposure at f/2 and a full stop overexposure at f/4 depending on the lens mounted. At narrower than f/4, the metering is fairly accurate until you reach the limits of the meter sensitivity (dim light and narrow apertures). The other advantage to Av mode is that you can use exposure compensation, though that is of limited usefulness since the amount of compensation to dial in varies by aperture.
OTOH...With your K-r, stop-down metering in M mode (using optical DOF preview as in the video) provides accurate metering with all aperture ring lenses. This is all in the camera manual, but is not very obvious.
Summary: Use M mode and be happy. Meter once and use that setting until either the subject or the lighting changes.
* This is in the camera manual and the reason is difficult to explain. Just take it on faith that M mode works consistently and Av mode does not.
