Originally posted by Michael Piziak Now, do I have to use the aperature ring to select what "F stop" I want to use?
I'm curious as to which F setting is best for macros. The aperature ring goes from 4 to 32.
The aperture affects the amount of light that comes in
It also affects the depth-of-field. So make your choice based on your needs. When you close down too far (f/16 or higher like f/22 or f/32), you will get poorer results due to diffraction.
Originally posted by Michael Piziak I tried to set the ISO to auto, but it doesn't have that option. My camera is in M mode and Manual switch selected in front. Perhaps that is only an option with an automatic lens?
Auto-ISO is not available in M mode. M-mode with auto-ISO is called TAv and is not available on your camera (as far as I know).
Originally posted by interested_observer I actually prefer to use the Av mode. I think that most folks around here use Av more than the Manual mode for manual lenses. With manual lenses (M42 screw mount, K and M lenses) you can use either M or Av modes.
Are you sure about K and M lenses in combination with Av?
