Originally posted by jatrax May I politely suggest you read through the manual and find an explanation of the various focusing and metering modes, I think the manual explains them better than I can.
The manual is a good thing.
I have my K10D in front of me and your options in terms of AF focus points are:
- AUTO (camera chooses the AF point)
- SEL (you choose which focus point to use)
- Center (camera uses the center AF point only)
To trigger AF you can half-press the shutter --or-- push the AF button on the back of the camera. Next to the lens mount is a switch that allows you determine AF mode:
- AF-S (single, shutter will not fire unless focus is attained)
- AF-C (continuous AF attempted, shutter will fire if pressed regardless of whether focus has been attained)
- Off (AF decoupled)
There are other options available through the set-up menus, but they are all variations on the above.
FWIW, I have found AF-C to be almost useless, though there might be some utility if used with continuous drive mode (aka "spray and pray"). I have also found the AUTO setting to be fairly disappointing. The camera usually defaults to the first element in the field that attains focus for any of the eleven points.
