12-29-2013, 06:14 AM   #1
jhaji's Avatar
*ist DS menu scrolling problem
It started after I put in recharged batteries. When I turn the camera on, the set date menu appears on the LCD screen and the selection keeps scrolling thru the options.
It scrolls thru anything on the menu screen.
I had a Tair-3 mounted when the problem first occurred. I suspect I laid the camera on its back and the 4-way menu wheel has got stuck.
It is currently only useable in the current menu settings. Only the mode, aperture, shutter speed and exposure compensation can be changed.
Any suggestions?
12-29-2013, 08:00 AM   #2
manacho2005's Avatar
If it were a WR body, I would say run warm tap water over it; BUT DON'T DO THAT.
Try taking the batteries out, drop a little rubbing alcohol on the wheel and massage it. If that doesn't free up the wheel, a new body might be in your future.
Good Luck
12-29-2013, 08:18 AM   #3
jhaji's Avatar
I ran a toothpick around the edge and got out a bit of crud but that did not free it up. At some point, I will resort to ur suggestion at some point and then leave it in a bag of silica gel to dry off the residual moisture.
I have other bodies but am just not ready to let go of the DS yet I think it is the CCD.
12-30-2013, 07:39 AM   #4
Don't use water. Use electrical contact cleaner.
*ist ds menu, camera, menu, pentax help, screen
ist DS flash problem cooneym Troubleshooting and Beginner Help 5 07-13-2013 03:32 PM
Debug menu for *ist DS v2.01+ jfsavage Pentax DSLR Discussion 6 12-13-2012 01:52 PM
Pentax ist DS horrible over exposer (?) problem. anarot Pentax DSLR Discussion 14 05-27-2012 10:05 AM
Ist DS problem using 4gb card kjfishman Pentax DSLR Discussion 2 02-16-2012 04:58 PM
Problem with *IST DS MENU BUTTON asplandl Pentax DSLR Discussion 1 09-17-2010 06:08 AM
All times are GMT -7. The time now is 01:19 AM. | See also: NikonForums.com, part of our network of photo forums!
