Originally posted by pketch It's a SanDisk Extreme 32 GB SDHC Class 10. I didn't format it the first time I used it, but after getting all of the files off of the card I have formatted it each time.
That's good, are you able to copy the files through the operating system from the camera to the hard drive?
UPDATE: Somebody had the same message and posted on
Adobe support, The original poster ended up plugging the cable into a different USB port and the problem was solved. Hopefully you have another USB port and that solves your problem too. I know a lot of USB ports do fail.
