01-01-2014, 02:16 PM   #1
50 1.4mm focus ring problems
I have a 50 1.4 M that has a focus ring that barely moves. How difficult is it to repair? Is there a You Tube video that anyone knows of that shows how to disassemble it?
01-01-2014, 02:38 PM - 1 Like   #2
Not a Number's Avatar
Check out this thread:
https://www.pentaxforums.com/forums/114-maintenance-repair-articles/179884-pe...-database.html
Which has the following links
M50 1.4
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/192993-gre...ns-repair.html
While these are mainly concerned with cleaning the lens groups dis-assembly of the helicoid usually doesn't involve these steps. Once you remove the trim ring (engraved) there should be another set of screws holding the filter ring on. Removing the ring usually gives you access to the helicoid focus barrel and can be unscrewed at this point.
Make sure you have a set of JIS cross drivers. The JIS screws look like Philips but there is enough of a difference that a Philips screwdriver can strip out the heads.
If you need helicoid grease I've been using this product:
http://www.amazon.com/Helimax-XP-Telescope-Instrument-Focusing-Helicoid/dp/B...8612882&sr=8-1
This appears to be of very good quality. You can find it on eBay and will ship internationally.
01-01-2014, 02:48 PM   #3
I will check this out.
Thank You very much!
1.4mm focus, focus, focus ring issue, pentax help, stuck
SMC Pentax F 35-70mm F 3.5- 4.5 Focus Ring Problems (It' s jammed) urssu Pentax SLR Lens Discussion 7 06-30-2013 08:55 AM
Pentax M 50 1.7 jammed focus ring Mr Manual Pentax SLR Lens Discussion 6 04-26-2013 09:53 AM
Stuck focus ring (Pentax-A 50mm F/1.7 Barron Pentax SLR Lens Discussion 4 07-18-2012 04:18 PM
DA21mm lens problems: focus ring play Beau Pentax SLR Lens Discussion 2 06-27-2011 07:34 PM
50-135mm focus ring kbryant Pentax SLR Lens Discussion 2 01-20-2011 03:39 PM
All times are GMT -7. The time now is 04:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
