01-06-2014, 11:42 AM   #1
Buying first DSLR
Hello all,
New to the forum.
I am looking at finally getting a DSLR after several years of owning just a small Olympus point and shoot for digital. Family and money constraints have mostly held me back from getting a DSLR. But I've been looking at some (primarily the K2000) on ebay and it looks like I can get into a DSLR pretty reasonably if I buy a used camera.
I have a few manual lenses for my old K1000 - Pentax 50, Toyo 28-75, & 75-150 zoom, and a Sigma 400 tele that I would like to be able to use to start with at least, so the Pentax has a great advantage in that their dslr's are all k mount.
the K2000 seems like a pretty good starter, fairly basic, uses standard AA batteries, most have a couple of lenses in a package to start with - I'm guessing that's how they were sold new.
I'd really like to stay under $200 to get started if possible.
I'd sure like some input/thoughts on pros and cons of the K2000 or if there are other models that I should be considering.
Part of the reason I loved my old K1000 was the simplicity and ease of use of the camera, I also have a Minolta Maxxum that I was never really comfortable with, I used it quite a lot, but it was never a favorite. (if the body hadn't cracked on my K1000, I probably wouldn't have used it at all!)
thanks for any idea's/feedback,
Dan
01-06-2014, 11:59 AM   #2
boriscleto's Avatar
You should be able to find a K-x for around $200 and it is a much better camera than the K2000.
01-06-2014, 12:03 PM   #3
QuoteOriginally posted by boriscleto Quote
Yup. The K-x has video and live view, a faster top shutter speed, and a much better sensor. Definitely get one of those IMO!
Pentax Cameras | Pentax K-m vs. Pentax K-x - Pentax DSLR Comparison - PentaxForums.com
01-06-2014, 12:12 PM   #4
Yup. K-x. You might have to shop & be patient.
01-06-2014, 01:06 PM   #5
Roob-N-Boots's Avatar
I would suggest going through KEH since they offer a 6 month warranty on their used products. They happen to have a K-x at the moment.
Pentax Digital Camera Bodies - KEH.com
01-06-2014, 01:25 PM   #6
Looks like another nice camera is available here:
https://www.pentaxforums.com/forums/24-photographic-equipment-sale/245316-sal...-k-x-body.html
01-06-2014, 01:38 PM   #7
Just1MoreDave's Avatar
The K-x has a huge advantage at higher ISOs, the equivalent to film speed. You can get excellent shots at ISOs where the K2000 is just barely hanging on. It's worth going over budget slightly. You'd pay a great deal more to get faster lenses that would give you similar low-light ability. The extra 2 Mp is not important. A lot of the non-sensor specs are the same between models.
You also will probably want a DA 18-55mm lens for inexpensive wide angle coverage. KEH has the L version for $35, the typical kit lens sold with either K2000 or K-x. The sensor is smaller than film, so your old lenses aren't very wide on the new camera. If you are not going to use a film camera at the same time as a DSLR, I recommend skipping all the threads explaining "focal length equivalence". Just get the 18-55 and see how it works for you. It also allows you to use a lot of your new camera's features that aren't available with some older lenses.
01-06-2014, 03:43 PM   #8
Definitely the K-x. I started with a K2000 and followed up with the K-x. It's without a doubt much better.
But I did have some problems with rechargeable batteries, and found that lithium ions were the best and pretty long lasting. When using rechargeables then Eneloops worked best for me.
01-06-2014, 04:03 PM   #9
Na Horuk's Avatar
Welcome to the forum! Since everyone is championing the K-x, I would just like to say that the K-r is a slightly tweaked version of the K-x. The K-r is a little larger, but it has the same sensor. The main improvement is that it shows you AF point overlays in the viewfinder, and that it was made after the K-x (so the units are less old). A used K-x or used K-r will cost almost the same. I don't know why the K-x is more popular than the K-r - on paper, the K-r should be better and costs almost the same. Oh, and I think both of these allow the use of AA batteries, with an adapter.
The K-m has an older CCD sensor. Some people like the way CCD sensors render colours, but these sensors do not allow live view and movie recording. Depends on what your priorities are, I guess. But digital cameras are evolving quickly, and each new generation offers something the previous ones didn't.
Either way, we are glad another Pentax SLR shooter decided to go digital and join the forums
Oddly enough, the K-30 and even K-5 can be found pretty "cheap" these days (though, still double the cost of a K2000) and they will fulfill your needs for a couple years at least - great 16MP sensor, weather resistant, and high end features. Just sayin', might be worth the stretch
01-06-2014, 04:11 PM   #10
Hi
K-x is great, but since you are looking at the used market.
I can assure you a lot of noobs out there discard their great Pentax cameras for a lot more cheaper than they should be.
So check out other models like Pentax K-50 or a K-5 as mentioned above by Na Horuk.
Welcome to the forum and happy hunting.
Cheers!
01-07-2014, 05:15 PM   #11
Thanks everyone! Lots of info here to digest. This has given me lots to consider and first off it sounds like I should step up past the K2000 to at least the K-x! I will keep checking and when i finally make a decision I'll post it here!
01-07-2014, 05:40 PM   #12
jac
If you're in no rush, go to the Buy/Sell tab at the top of this page. Click it and a drop-down menu will appear. Click 'Pentax items for sale'. At the top of the new screen, you will see a black box with 'Watch New Keyword'. You can enter items you want in the search box and get notification if someone is posting the equipment you want. You can also go to 'Wanted Pentax Items' in the Buy/Sell tab and list your needs there.
01-07-2014, 05:49 PM   #13
Pepe Le Pew's Avatar
K-30 or the k-50..........
01-08-2014, 10:34 PM   #14
Yos
Another vote for the K-r! But if you find a good deal for a K-30 go for it
01-09-2014, 07:26 AM   #15
Another vote for the K-x. Great IQ, excellent low-light/high ISO capability, nice ergonomics, compact. I've had two of 'em for a couple of years now & don't feel the upgrade bug yet. They do everything I need them to do. And you can get one cheap. Gotta like that.
Nothing against the K-r, but personally I would prefer the K-x, just because the K-r has had some reported mirror flop issues.
camera, dslr, k1000, k2000, lenses, pentax, pentax help, photography
FIrst DSLR and First Pentax mellowyeahlow Welcomes and Introductions 11 06-26-2014 08:29 AM
A beginner seeking help on first lenses with first DSLR (K-30) Mr008 Pentax SLR Lens Discussion 25 09-13-2012 05:07 AM
buying my first flash no694terry Flashes, Lighting, and Studio 27 04-27-2012 07:05 PM
Buying first DSLR (k-x or k-r) flyingP Pentax DSLR Discussion 5 10-20-2011 03:29 PM
Buying DSLR - Urgent Advice needed suesydney Troubleshooting and Beginner Help 19 09-19-2009 12:44 AM
All times are GMT -7. The time now is 03:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
