01-08-2014, 01:32 PM   #1
K100d not working
Hi I need help have a k100d not working just a clicking sound when you press the button any advice ?
01-08-2014, 01:36 PM   #2
First thing I would do is check the battery.
01-08-2014, 01:38 PM   #3
QuoteOriginally posted by Jimmy Quote
Hmmm, I get a clicking sound when it works!
Any other info? Camera seems to power up normally, etc? Does it sound like the shutter is moving, or the mirror is moving, or neither?
01-08-2014, 02:08 PM   #4
QuoteOriginally posted by ElJamoquio Quote
Battery ok clicking sound constantly when button is pressed ?
01-08-2014, 11:00 PM   #5
Which make / type of batteries? Do you have another set to test? Batteries (even the best ones) don't have eternal life.
01-09-2014, 03:18 AM   #6
Hi battery ok , camera working eg, rear display etc but in picture mode when you press the shutter button it just constantly clicks if you hold the button down ?
01-09-2014, 04:47 AM   #7
Camera not working
Battery ok. No shutter sound , if you press the shutter button only a continuous clicking sound , the rear display is working ok you can look at the pictures ?
01-09-2014, 05:46 AM   #8
In mine k100d cleaning batterycontacts did solve similar problem.
01-09-2014, 07:11 AM   #9
QuoteOriginally posted by Joojoo2010 Quote
Thanks I will give it a go tonight
01-09-2014, 11:12 AM   #10
The fact that certain things work does not mean that the batteries are still ok. Take a car battery; you might still be able to listen to the radio with it while you're not able to start it. In which case the battery is not ok.
Just saying
01-09-2014, 01:41 PM   #11
QuoteOriginally posted by sterretje Quote
Just saying
Fair point will try new batteries tonight thanks.
01-10-2014, 04:39 AM   #12
Put in new Duracell batteries last night no joy,still just the same. Where is the best place to send my camera for repair live in the Motherwell area in Scotland . Any help would be mutch appreciate Thanks
01-10-2014, 09:47 AM   #13
You'll probably spend much more fixing it than you will replacing it. you can get another K100D for around $125 USD.
01-10-2014, 10:50 AM   #14
QuoteOriginally posted by GibbyTheMole Quote
Thanks only used it for 1 month bought it 2nd hand on ebay that's life. Thanks for the reply. Cheers
01-10-2014, 11:06 AM   #15
One circumstance I had with similar syptoms: my K-r was in Catch -in (trap) focus mode without my realising it. If thats on, then the shutter won't fire if the camera doesn't think is in focus. Check your settings, check if st happens when you hold the shutter button down and focus manually. If you were using an AF lens in any case then this doesn't really apply.
In any case go right thorough the set up menu and checK everything looks Ok.
Reboot? The only way I know of to do a "reboot" is a firmware update, definiitely try that. Eventually if nothing works then the conclusion is another electrical device with a glitch somewhere, who knows where, main ICB, sub component...
I second not economical to repair in that case: even if a replacement ICB/part was available. DIY job for s/o really keen basically, get another k100 off ebay spares/repairs...
But FYI
CAMERA REPAIRS, LENS REPAIRS in WEST LONDON , SURREY , TW17 , TW18
MWCameraRepairs
k100d, pentax help, problem
SDM 50-135, not dead, but not working Olek Troubleshooting and Beginner Help 13 12-07-2012 07:42 AM
Pentax K100D Super with Sigma 28-200mm lens - Not working? JSM Graphics Troubleshooting and Beginner Help 3 04-08-2011 09:35 AM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
1:1.7 50mm is not working with k100d Karoliz Pentax DSLR Discussion 3 07-14-2009 09:40 AM
The e-dial on my "new" K100D is not working NorthPentax Pentax DSLR Discussion 6 05-17-2009 08:14 AM
All times are GMT -7. The time now is 02:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
