01-11-2014, 07:27 PM   #1
Exposure Mode setting
I am new to Pentax. Just bought a K3. Great camera.
I am wondering which exposure mode most people use. TAv looks good. If I wanted to be able to adjust the aperture I can do it in this mode. I also can do it using Av. So what is difference between the two?
Thanks.
01-11-2014, 07:30 PM   #2
QuoteOriginally posted by Bigdomino Quote
Thanks.
You'll probably want to stay in P or Av mode if you just want to adjust the aperture. Doing it in P mode is a breeze as you can always go back to full auto just by hitting the green button. TAv is where you set the shutter speed + aperture manually and the camera tweaks the ISO setting to achieve proper exposure.
01-11-2014, 07:31 PM   #3
SpecialK's Avatar
Here is the poll.
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/227309-what-your...sure-mode.html
No need for another thread :-)
01-11-2014, 07:31 PM   #4
Canada_Rockies's Avatar
With TAv, the camera will adjust the ISO for correct exposure. With Av, the ISO is usually fixed and the camera adjusts the shutter speed for correct exposure.
01-11-2014, 07:37 PM   #5
I will try each. Maybe Av would be better. I would like to keep the ISO as low as possible for reduced noise in the images. Am I thinking about this correctly?
01-11-2014, 07:53 PM   #6
By using the Av mode the ISO moves up and down. Should I let it or lock it in at a low level?
Thanks.
01-11-2014, 08:14 PM   #7
You can also set a predefined ISO range, for example, you can set it so that ISO will be automatically selected from ISO 100 to ISO 1600. It would then never go outside that range.
01-11-2014, 08:15 PM   #8
What ISO level will start to impact the quality of the image?
01-11-2014, 08:18 PM   #9
I usually find anything under 1600 to be easy to work with, obviously, you want as low as you can afford with your other settings.......I am sure those more experience with touching up photo's can deal fine with higher ISO...
01-11-2014, 09:56 PM   #10
sterretje's Avatar
Don't use auto-iso if you don't want the camera to change it Just set it to 100; when you find that shutter speeds become to slow, manually increase the ISO.
What you use depends on what you need; I mostly use Av with fixed ISO and in some situations I use TAv with floating ISO.
01-11-2014, 10:06 PM   #11
Wanting to maintain the highest image quality is an excellent goal. However, to that end - think the entire problem through. Several times, I have not thought the problem through all the way, and somewhat held the ISO artificially low, only to find that other conditions prevailed and the shots did not turn out as expected. So, yes - do try to maintain the lowest ISO, but there are times when either shutter speed, aperture or both become much more important and ISO just becomes what ever is necessary to capture the shot. Also, consider taking several shots - where each one may emphasize a different approach (fast shutter, narrow aperture, or low ISO, or what every combination) - with digital the film is essentially free.
I like to shoot square rigged sailing ships at sunset. With the tide moving the ship, and breeze moving the rigging, (a pretty short exposure) and wanting a good depth of field (needing to stop down the aperture) - the ISO just becomes what ever is necessary to get the shot.
It is good to correctly expose the image when capturing it. In post processing you have a second opportunity to make adjustments. You can apply noise reduction utilities, along with sharpening and contrast adjustments - to help mitigate higher ISO's than what you may have wanted. There are always additional techniques to help out.
camera, exposure, exposure mode, mode, pentax help, photography
Exposure +/- setting jwmster Troubleshooting and Beginner Help 7 01-13-2014 07:45 AM
Exposure compensation vs flash output setting Kozlok Flashes, Lighting, and Studio 8 12-31-2013 10:02 AM
setting 6400 - 12500 in movie mode ??? pass Pentax K-01 3 10-03-2013 12:24 PM
Pentax Kx sensor wobble at long exposure setting Amante Troubleshooting and Beginner Help 28 07-04-2013 05:40 PM
Setting a User mode to mimic Tri-x Finn Pentax DSLR Discussion 5 01-17-2013 09:25 AM
All times are GMT -7. The time now is 06:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
