01-14-2014, 03:10 PM   #1
Just broke my Tamron A17 70-300mm
I won a nice, second hand, Tamron A17 70-300mm on eBay, and had it delivered this morning. Gave the focus and aperture rings a quick twist when I unpacked it to make sure they worked, then did the same with the zoom, but harder than I meant to. Everything seemed ok, so I connected it to the camera (K-x). Realised then that the zoom wasn't doing anything. The ring twists, but nothing happens. Looking at it, I think I had it set to Macro when I twisted the zoom ring, not realising it should only go so far
Does anyone know what I've broken? Something rattles now when I shake it. It's not worth sending off for repair, as it was so cheap, so I'm going to try fixing it myself. Any hints or tips so I don't make it worse?
This is the eBay listing:
Tamron A17 70-300 mm F/4-5.6 LD Di AF Lens Pentax 62mm 0725211177142 | eBay
01-14-2014, 04:18 PM   #2
Julie's Avatar
Mount the lens on your camera, set the camera on MF (manual focus).
Take the lens and zoom it in to the 70mm end, see if you can move the switch on it out of "Macro".
See if that does anything.
01-14-2014, 05:16 PM   #3
Sorry to hear about your misfortune.
Attempting to repair a modern zoom lens is not for the faint-hearted.
Unless you have good knowledge of lens repair, you'll most likely do more damage than good.
01-14-2014, 05:29 PM   #4
Hi Julie, thanks for the reply
I forgot to mention, the macro switch seems to be working, in that it only switches when the lens is set to 180 - 300mm, and only lets the focus ring move to the macro settings when it's engaged. It looks like I've disconnected the zoom ring from the rest of the body, but it still rotates to the correct positions.
Hi Tom
I definitely agree with you there! Unfortunately for this lens, it would cost me more to get it fixed than it would to buy a replacement. I'm going to treat this as a learning exercise, and see if I can do anything about it. If not, I've got a fancy looking 70mm lens
01-14-2014, 08:09 PM   #5
patrick9's Avatar
Ive got the Quantaray LD 70-300 macro (rebadged tamron LD). I am surprised you could turn the zoom ring past the stops in macro. Mine would take a wrench I believe to go past the 180 stop with it switched to macro . No way to do it accidentally. Sounds as if it may have been broken when you got it.
01-15-2014, 07:12 AM   #6
Quite possibly. Unfortunately for me though, I heard a crunch as I turned it, so have no way of knowing who broke it, and wouldn't feel right sending it back to the seller when it probably was me
I've got the hammer and chisel out, so if that doesn't fix it, I don't know what to do...
01-15-2014, 07:18 AM   #7
mrNewt's Avatar
That crunch noise is something you never wanna hear on a lens like that.
Honestly... someone has to look at it (someone that knows how to fix lenses). You won't fix it "over the internet" that's for sure ...
And for the love of what is dear to you... put. the. chisel. and. hammer. away!
01-15-2014, 07:32 AM   #8
Fine! I'll go get the hacksaw and blowtorch instead
01-16-2014, 12:57 AM   #9
QuoteOriginally posted by Tippon Quote
The ebay listing is a little dubious. First of all you can`t buy the ``wrong size`` K mount lens as claimed.
And of course the old standby ``I have not checked to see if it works`` so the seller can claim he didn`t know.
I would go back to the seller and ask for a refund.
01-16-2014, 01:18 PM   #10
Hi Hartless_1 (love that name! ), thanks for the tip
Like you say, looking back, the ad does look a bit iffy. I'm pretty sure it was me that broke it though. When I twisted it and got the crunch, it felt like something gave. I'm treating it as a slightly expensive lesson in how to repair lenses. I've been a computer engineer for years, and have plenty of experience in repairing small fiddly items, so this is more like a branch in a new direction
All I need to do now is remember where I put my small screwdriver set
70-300mm, a17, ebay, pentax help, tamron
For Sale - Sold: Tamron (Model A17) 70-300mm f/4-5.6 Di LD Macro AF Lens for Pentax. grahame Sold Items 1 11-21-2013 03:20 PM
Replacing my 70-300mm (Tamron or Sigma?) ChrisTrevino Pentax SLR Lens Discussion 9 08-03-2013 01:01 AM
Just got my Tamron 70-300mm Lens! hockmasm Pentax SLR Lens Discussion 11 09-30-2010 09:30 AM
For Sale - Sold: Tamron A17 70-300mm/4-5.6 AF LD Di Tele-Macro 1:2 (EUR) axl Sold Items 5 08-03-2010 12:03 AM
Help! My DA* 16-50mm just broke! SA Photo Pentax SLR Lens Discussion 17 12-10-2009 03:33 PM
All times are GMT -7. The time now is 09:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
