01-15-2014, 09:33 AM   #1
lens element problem
i found this ghost like layer in my lens.. im not sure if its fungus or water damage or dust or jus simply the coating of the lens deteriorating,, can anyone please help me fix this.. i wanted to make the glass clear again.. any advice guys? maybe some DIY instructions?? my lens technician doesnt have an idea on how to clean this lens.. the lens is a bonded lens element.. it looks like 2 pieces of lenses bonded together..
thanks guys..
P.S. .. the two circles you can see on the lens are the LED lights i placed under to light up the background
Lumia 520  Photo
01-15-2014, 10:36 AM   #2
jatrax's Avatar
If it is between two bonded elements it will be very difficult and expensive to repair. Eric has done this for me once. He had to separate the elements, remove the old cement, then re-glue it back together correctly aligned. That's if it is just separation. If there is also fungus involved that might complicate things even more.
Which lens is this? You need to consider the cost of a replacement to decide if it is worth it.
01-15-2014, 10:37 AM   #3
You photo looks like a real bad fungus infection infiltrating the glue between bonded elements.
help, lens, lens element, lens., needs cleaning, newbie ;, pentax help
7 element super takumar vs 8 element 50 1,4 fikkser Pentax SLR Lens Discussion 3 07-13-2013 07:59 AM
Help - Blurness problem encountered, on lens element? KDAFA Pentax SLR Lens Discussion 12 02-19-2013 08:32 AM
Lens element separation? Mamiya 50mm pz1fan Non-Pentax Cameras: Canon, Nikon, etc. 3 12-19-2012 05:32 AM
8 element vs 7 element 50mm f1.4 RMJ Troubleshooting and Beginner Help 8 09-19-2011 12:11 PM
Damaged rear lens element on F70-210, can the element be replaced? WendyB Pentax SLR Lens Discussion 13 01-05-2008 08:41 AM
All times are GMT -7. The time now is 10:41 AM. | See also: NikonForums.com, part of our network of photo forums!
