Originally posted by ClinchShots well I checked my sensor again and it looks fine I moved it around a bit to see if there is any scratches or specs and I see nothing
camera is pretty much clean now except for when I use the viewfinder
pictures are sharp and look good to the eye
Re Your Sensor....Turn on your dust removal in the Tool menu #4. I have mine set to start up. That will shake dust off the sensor when you start your camera. Periodically you will need to blow off the sensor with a Rocket Blower or something like it.
Re Viewfinder... Don't OCD on that one. That is part of life with interchanging lenses. Blowing it off with a rocket blower will help most of the time. Periodically I will drop my view screen and blow out the mystical dust particles that get behind it but you need to be in a dust free area and be careful when you do. It can be Gently removed and cleaned carefully also.
