01-20-2014, 05:14 PM   #1
Bolt VS510 Flash and K30
Trying to get my K30 to connect wireless to a Bolt VS510 and not having any luck. Does anyone have this combo and get it to work?
01-21-2014, 08:46 PM   #2
sterretje's Avatar
Wireless using the pop-up flash or wireless using radio triggers?
Maybe describe the steps that you have taken (both on the camera and on the flash). Somebody might be able to point out what you have missed. I don't have experience with off-camera flash (and I don't have the Bolt nor can I find a user manual for the Pentax version of it) so probably can't further advise.
01-22-2014, 01:49 AM   #3
aurele's Avatar
acording to B&H the wireless mechanisme is "Optical pulse". Maybe it means that your on body flash should "flash" to trigger the Bolt ?
edit : if the K30 menu is the same as the K-x, then press the button with the flash logo (left button from the directional pad), then you should be able to choose the type of flash, including wireless ones.
bolt, bolt vs510 flash, k30, pentax help
Help with flash and indoor photography (K30) jaikumarr18 Pentax K-30 & K-50 38 02-16-2014 06:40 AM
Metz Flash (s) and the K30 geru2000 Pentax K-30 & K-50 4 10-10-2013 03:05 PM
Compatible lens and flash for K30 rdlcud Pentax K-30 & K-50 7 08-19-2013 08:23 AM
Bolt VS-510P Flash...anyone have one? CRMassart Flashes, Lighting, and Studio 0 05-10-2013 05:00 AM
All times are GMT -7. The time now is 09:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
