01-26-2014, 04:28 PM   #1
MadMathMind's Avatar
Neutral Density Filters and DoF
Simple question: Do neutral density filters alter the DoF that would normally be associated with a given f-stop? For example if I put a two-stop ND filter on a lens set to f/2, is my DoF like f/2, f/5.6 or something in between?
01-26-2014, 04:32 PM   #2
Otis Memorial Pentaxian
No.
Sorry for the brevity, but the filter merely reduces the light reaching the sensor in the same way as a cloud over the sun.
01-26-2014, 04:59 PM   #3
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by MadMathMind Quote
No ND's just knock down light, aperture remains as is, hence dof unchanged.
01-26-2014, 07:35 PM   #4
ND filters act in a similar manner to the aperture in that you can apply them as needed to reduce the amount of light getting to the sensor. However, the ND filter or any physical filter attached to the lens for that matter acts independently of and in series to the aperture. And as you observed, essentially you can use the filters to control the light and the aperture to control the depth of field.
Since the filters are a light control element, it is good practice to use high quality filters, especially on high quality lenses. A crappy filter up front, does not enhance the capability of an excellent lens.
01-26-2014, 08:47 PM   #5
Thanks, guys! I recently took some photos with an ND filter at f/2 with a 50mm lens (first time with an ND), but didn't quite give the bokeh I was hoping for. I was worried the ND filter killed my blur, but I guess I was just a bit too far away from my subjects to get the super blur I was seeking.
density, density filters, dof, f/2, filters, pentax help
neutral density filters shaolen Pentax Camera and Field Accessories 3 08-12-2013 10:44 AM
Neutral Density Graduated Neutral Density Filter questions tessfully Pentax SLR Lens Discussion 36 04-11-2013 07:01 AM
Neutral Density Filters pearsaab Pentax SLR Lens Discussion 17 08-31-2012 08:15 AM
For Sale - Sold: 72mm neutral density and CPL filters slawek Sold Items 3 10-24-2011 03:58 PM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
