Originally posted by UncleVanya Thanks for clarifying a few things. Most of this is what I already was doing but turning off jpg sharpening was a new trick. I also had not had confirmation about CDAF not using adjustments so that is helpful to know also.
Also the camera should be set to a neutral setting. Standard or neutral or natural, I forget what it's called on Pentax - his instructions are using some Canon terminology and my camera isn't in front of me to check it.
The forum link is
here, but to save some time, here's his list of "Best Practices" which includes some canon/nikon specific issues that don't apply with Pentax.
- If Outdoors, use Aperture Priority Exposure - OK if lighting varies slightly - watch for glare and shadows
- If lighting is constant artificial source (indoors), use manual exposure, manual ISO
- Set Picture Style to Standard (not Vivid, Landscape, etc.)
- Large-Fine Camera-shot JPEG images (not RAW conversions)
- Single Center point AF (not Spot AF on Canon)
- Single shot (not continuous)
- Fixed White Balance (not Auto)
- Shoot Wide open (in some cases it is best to shoot 1/3 to 1 stop down, especially with lenses 1.4 or faster)
- All stabilization systems OFF (Canon IS, Nikon VR, etc)
- Shake avoidance techniques
- AFA settings (AF MicroAdjust or AF Fine-Tune) should be made to the "per lens" or "saved value" setting, not the "default" or "all lenses" setting
- de-focus between shots slightly, in the same direction (towards "closer", not infinity....do not de-focus to extremes)
- Do not shoot in Live View mode
- Do not use rear AF button on Canon cameras (Canon bug).
- You should use a cable release or self timer.
- Use highest exposure without causing the ruler or target to clip (watch the blinkies on the rear LCD to determine exposure)
- ISO up to 1600 if needed (better to use ISO 1600 than to risk camera shake with lower shutter speed)
- DX Crop mode on Nikon (just to keep file size down), but FX/DX does not affect outcome
- Position LensAlign and Camera using True Parallel Alignment, then mount Large Gen 3 Focus Target
- Viewfinder eyepiece closed
- Shutter Delay Mode (Nikon)
- Self-Timer (Canon)
- Cable release
He also suggests broad tuning before fine tuning -- take 5-10 photos each at -10,-5,0,5,10, then run them through the software (or without it, just eyeball them, I guess) and that should give you a good idea of where to fine tune (i.e., if your sharpest images are at -5, and -10 is worse than 0, you should run another set at something like -6, -4,-3, -2, and -1.
The FocusTune software is nice because it does the comparisons in seconds, and it's more accurate. Like, here's my result for my 77mm ltd, which shows that my best adjustment is probably -4/5 and I need to do more testing (shot deviation should stay under 100 - the lower, the better.) It's too bad it's fairly expensive and the license is only good for 2 computers.
