02-01-2014, 07:32 PM   #1
g026r's Avatar
K-30 Won't Turn Off
Well, it does now.
Whilst out shooting today, I had it remain stuck in live view mode. Wouldn't turn off. None of the buttons would respond. Yanking the battery was the only way to get it to do so.
Turned it to off, waited a few seconds, then put it back in. Mirror slapped back into place, buttons responded, and everything seemed fine.
This is a new one for me. Anyone have similar experiences?
02-01-2014, 07:38 PM   #2
QuoteOriginally posted by g026r Quote
Well, it does now.
This stuff happens from time to time. If your battery voltage is low, or if the drain is high, it's more likely to happen. But if all's good after the battery pull, then you're good
02-01-2014, 07:52 PM   #3
Na Horuk's Avatar
This should only cause concern if it happens often, or regularly.
In the mean time, dismount the lens and make sure the mount/contacts are clean.
Also, make sure your camera has the latest firmware. These things might not be the cause of the problem, but its good to check just in case.
And maybe you want to buy another battery. Many glitches are results of battery faults or fluctuations
02-01-2014, 07:53 PM   #4
Emperor and Senpai
VoiceOfReason's Avatar
It has happened with my K5 when I ran the battery lower than I should have. It doesn't seem to hurt anything, just stick a fresh one in and you're set.
02-01-2014, 07:59 PM   #5
g026r's Avatar
Voltage was good as I charged it last night, and drain shouldn't have been much worse than any other day. Firmware's all up to date as well.
If it's something that happens from time to time normally and only a problem if it keeps happening, then I'll keep an eye on it but not worry too much.
Thanks everyone.
02-01-2014, 08:10 PM   #6
causey's Avatar
Happens to my k-30 once in a while.
02-01-2014, 08:27 PM   #7
EarlVonTapia's Avatar
Well, it does now.
It's happened a few times for me. I've never thought anything of it other than "cameras are complicated".
25,000+ shutter count, original firmware, still ticking . . .
02-01-2014, 08:29 PM   #8
I experienced this also when i first used my camera with the battery with factory charge. The k-30 is very sensitive to a partially charged battery
02-01-2014, 10:02 PM   #9
Happened to me on the K3 as well....and the battery was full
02-01-2014, 10:03 PM   #10
Happened to me with the k3 as well
02-01-2014, 10:07 PM   #11
Try to remember that modern digital camers are a lot more digital than camera. As such, they're subject to the same idiosyncrasies that you experience with your PC, laptop, smartphone etc. Keep your firmware up to date. Don't use weak batteries. Back up your pictures frequently and don't rely on flash media. SD cards are cheap. Replace them fairly often.
02-01-2014, 10:26 PM   #12
Julie's Avatar
It used to happen to my K-30 once in a while...
I sent mine in to repair to CRIS (for a different issue) and while they were at it, they upgraded the firmware to the newest (I'd previously been running the original) and I can't really recall having much trouble with this issue ever since...
02-01-2014, 10:55 PM   #13
SpecialK's Avatar
A not uncommon problem in Pentaxland. I would not worry about it unless it happens a lot, or your mirror starts to flop.
02-02-2014, 07:58 AM   #14
wow it never happened to my K-30 but I think it happened to my K-5 once (situation seems similar). Will this be a common issue?
02-03-2014, 09:57 PM   #15
donfenix's Avatar
It happened to me a couple of times when I was still on firmware 1.02 or 1.03. It has never happened to me on 1.04 or 1.05. What firmware are you using?
buttons, pentax help
K-5 won't turn off Mareket Pentax K-5 19 09-10-2013 08:14 AM
K-5 won't turn on sophie100 Pentax K-5 16 06-01-2013 02:16 PM
K-x won`t turn on Rick43 Pentax DSLR Discussion 6 03-25-2012 04:26 PM
Rear screen won't turn off? Todd Adamson Troubleshooting and Beginner Help 3 10-30-2010 09:37 PM
MZ-M LCD won't turn off knaff Pentax Film SLR Discussion 2 07-12-2010 04:30 AM
All times are GMT -7. The time now is 08:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
