Originally posted by TraciA Thanks for all your input! I haven't made it through all the replies yet!
The light meter is a Sekonic Flashmate L0308S.
I have the Sekonic 308S bought it last month. I don't or won't use it all the time but there are many times it is used especially inside and with flash, for the most part the camera does a pretty good job of metering the light.
With this meter you can measure reflective and incident light as well as flash.
I have the K30 and I can tell you that the camera and Sekonic meter readings are seldom the same. The sekonic seems to get it right much more than the cameras meter.
When I use the Sekonic I just set the camera as it recommends and don't bother with the the light meter in the camera which in many cases shows 1 to 2 stops lower.
