02-12-2014, 07:42 PM   #31
Canada_Rockies's Avatar
The dog would really rather you played "chase the stick" than putting that glass thing in his face, I think. Nice shot.
12-03-2015, 02:56 AM   #32
Jacchini's Avatar
I have the same issue as the original poster: the cheapo M39-M42 ring I got from the bay doesen't screw all the way into my (original Pentax made in Japan) M42-PK adapter. Very annoying... All the more since it goes into my Spotmatic and Zenit without problem. Did you find a solution?
12-03-2015, 07:31 AM   #33
Not a Number's Avatar
The M39 ring I got from Fotodiox will not thread completely into my Philippines made OEM Pentax adapters but will thread into my Japan made OEM Pentax adapter (labeled only PENTAX Japan - without ASAHI). The adapter threads into my Asahi Auto Bellows (screwmount) without problems.
Perhaps try a Philippines made Pentax adapter?
12-05-2015, 07:28 AM   #34
Jacchini's Avatar
I think I have solved my problem by wearing the threads (screwing in and out some twenty-odd times on a condemned spotmatic). I'm still weary to put the lens on lest I it get stuck in there... A drop of glue between the lens and the ring?
12-05-2015, 11:33 PM   #35
Probably easier and potentially cheaper in the long run just to buy another ring from a different source. And hope it is has a thread more within tolerance of the M42 thread.
04-14-2016, 08:29 AM   #36
IgorZ's Avatar
QuoteOriginally posted by cpritchardv Quote
Hey everyone, thanks again for your help.
I ended up ordering another one off of ebay, and it worked fine. This was the ring I used. Camera 42 39mm M42 to M39 Lens Mount Adapter Ring Hood Filters for Leica Zenit | eBay
The lens seems to have no issues focusing to infinity. Im looking forward to playing around with it. Heres one of my first pictures after getting it on my k-5ii
You mentioned that infinity focus does not seem to be a problem, is it still the case? I guess the issue of M39 - M42 adapters has been discussed to death, but I didn't find a conclusive answer with a quick look through the forums. I am looking at an old Soviet lens with M39 mount. Trying to figure out if it can maintain infinity focus on my K5. This lens has a slightly shorter distance to the sensor, than K mount lenses (45.2mm vs 45.5). So is my understanding correct that basically I need to put this lens 0.3mm inside the body to maintain infinity focus?
04-14-2016, 08:46 AM   #37
QuoteOriginally posted by IgorZ Quote
I was able to retain infinity focus with that lens. I haven't tried using any other M39 lenses though, so I can't say for anything else unfortunately.
adapter, adapter problem, leica, lens, m39, m39 -> m42, m42, pentax, pentax help, pictures, screw, screwmount
Camera mount for Pentax M42 Auto Bellows? (NOT about M42-K adapter) baj Pentax Camera and Field Accessories 9 10-24-2011 10:42 PM
Recommendation for a good M39 to M42 adapter ducdao Pentax SLR Lens Discussion 18 01-21-2010 04:55 PM
M42>K adapter that stays on lens........ WJW Pentax SLR Lens Discussion 7 01-15-2010 06:54 PM
For Sale - Sold: Pentax OEM M42->K adapter heliphoto Sold Items 4 12-01-2009 11:12 AM
For Sale - Sold: Genuine Pentax K > M42 adapter Squier Sold Items 2 08-02-2009 10:31 AM
All times are GMT -7. The time now is 04:10 PM. | See also: NikonForums.com, part of our network of photo forums!
