Originally posted by YQG Evenin. I just had a third-party M42 adapter arrive today, and it's really really tight to mount to the camera (*ist D). I mean, so stiff I'm afraid something will break or I won't be able to get it back out. I haven't even manged to get it in all the way (owing to fear :P). It seems to want to pop out from being flush so I expect it's just a lot of tension on that particular vertical surface, but is it safe to just brute-force it in with the presumption that if it went in, it should come out (albeit with much effort)? Is this a common problem with cheap China adapters? I know a *ist isn't a particularly amazing or expensive camera but it's the only one I have and I don't want anything to bust. :P
Thanks!
I did purchase only one from China ( with infinity focusing, locking spring and removing tool) , took me a while to file it down so it would nicely fit.
I also had to shorten the spring screw, it was preventing M42 lenses from fully screwing in.
Then I purchased original Pentax ( one new + one used) , no problems at all.
Pentax K to M42 - a set on Flickr
Marumi was also OK, although a bit hard to remove, you need to use supplied tool .
Sold it when I purchased the real Pentax.
