Originally posted by dizon_dx Have any of you tried a DIY intervalometer? I'm trying to make one but the problem is it's not working, I'm not sure if it is because I didn't solder it or its with the IR LEDs I'm using or with the jack. I tried to buy a cheap earphones and used it. Regarding with IR LEDs I tried to use the ones in the old remote control (tried to recycle them
). Any tips on making DIY intervalometer? Thanks in advance!
What kinda circuit? If you are using the wired connection. then what is the purpose of the IR led`s.
Post a schematic so we can have a look at what you have so far.
BTW sounds like a fun project.
edit: you do realize that it is cheaper to buy one than to build one.
