02-09-2014, 02:31 PM - 1 Like   #1
k-5 and YN-560iii wireless flash advice needed.
Just purchased a Yn-560iii Speedlite and looking for a bit of information, I've got the flash working in S1 and S2 mode and I'm very happy with the results, however when trying to set up for wireless i can't seem to be able to get it to work, i thought as there is a wireless mode on my K5 it may have worked, I've changed the channel on the flashgun put it in the hotshot and turned camera on with no guide from camera as to what channel the its on. Cant even find what frequency the k5 is on.
Am i barking up the wrong tree and they operate on totally different frequencies, or does the K5 wireless only work with Pentax Flashguns, Just i don't want to go and buy transmitters/receivers if i don't have to.
02-09-2014, 02:59 PM - 2 Likes   #2
the k5 wireless is p-ttl, the yn560iii wireless is radio based. they are not compatible
you can get a yn wireless trigger (sits on your camera hotshoe) which can trigger the yn560iii wirelessly. search the forums for info on the yn rf 603 for more info
02-10-2014, 06:39 AM   #3
QuoteOriginally posted by jezza323 Quote
So it needs the trigger to use in wireless mode... It's good to know, I am planning to buy a yn560iii to replace my old Vivitar 1. Thanks for sharing!
02-11-2014, 02:05 AM   #4
EJMzagsfan's Avatar
Can't you trigger it as a slave with another flash on or off the camera? Or even just your cameras flash?
02-11-2014, 03:00 AM   #5
You can trigger it as an optical slave, yes
02-11-2014, 03:39 AM   #6
sterretje's Avatar
QuoteOriginally posted by EJMzagsfan Quote
If I'm not mistaken, the mentioned S1 and/or S2 in the opening post are for that.
02-11-2014, 12:10 PM   #7
EJMzagsfan's Avatar
QuoteOriginally posted by sterretje Quote
Ok, thanks I missed that. Im thinking of getting one of these, they get stellar reviews.
camera, channel, flash, flash advice, k-5 and yn-560iii, k5, mode, pentax help, photography, wireless flash mode, yn-560iii, yn-560iii flash, yn-560iii wireless flash
K-30 With YN-560III Flash jrcastillo Flashes, Lighting, and Studio 14 11-06-2013 12:24 AM
K-7 with the YN-510EX Yongnuo Wireless TTL Slave Flash Speedlite Steve.Ledger Flashes, Lighting, and Studio 11 09-28-2013 05:52 AM
Dropped my K-5 - advice needed bjdavey Pentax K-5 8 03-11-2013 06:01 PM
Flash advice needed SCADjacket Flashes, Lighting, and Studio 10 11-05-2012 02:29 PM
yn-560 flash +pentax k-5 Purusam Pentax K-5 2 03-12-2011 05:02 PM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, part of our network of photo forums!
