02-10-2014, 08:51 PM   #1
k-30 focus
I purchased a k-30 w/ 18-135 wr and a 55-300 pentax da lens and my photos seem to be not sharp. do I have to calibrate or use the af fine adjustment in camera.
PENTAX K-30  Photo
PENTAX K-30  Photo
02-11-2014, 01:48 AM   #2
It's hard to say if the softness is due to the typical performance of the lens itself, or other factors (such as a relatively slow shutter speed in the second shot). Can you post 100% crops and some more samples?
If the culprit is inaccurate focus, you can confirm by focusing via live view. If that yields a sharper result, here are the steps to correct front/back focus:
Fixing Front and Back Focus - Introduction - PentaxForums.com
02-11-2014, 06:08 AM   #3
QuoteOriginally posted by awesome 63 Quote
is there a aperture on the 55-300 da that will produce the best DOF. .I have started using is0 400 to eliminate slow shutter speed. I will use the AF adjustment to find the best setting . Thanks.
02-11-2014, 06:34 AM   #4
sterretje's Avatar
Solving focusing issues by increasing DOF is not the way to go. f/32 or so will produce the deepest DOF. Not advisable though due to side effects. Your apertures (f/9 and f/10) should give good results.
I would follow Adam's advice and try live view first. If that's OK, it indicates that you need to apply the AF fine tuning. I would also advise to see if 260mm works better; lenses are usually not at their best at the extremes.
02-11-2014, 09:33 AM   #5
I also have trouble with the K-30 and the 18-135. Most pictures are quite soft. This seems to be the case with most AF lenses. My old 50 1.7 manual lens is super sharp in comparison. Please let us know if AF tuning or similar helps. I have tried it myself without success. Even sent the camera and lens for warranty service but got it back the same way.
k-30
Pentax K-30 focus confirmation issue tpetris Pentax K-30 & K-50 10 12-28-2013 04:31 AM
k-30 or k-5 focus confirm with legacy glass? pixelvandal Troubleshooting and Beginner Help 6 06-15-2013 06:58 PM
k-30 focus problem mtkang Pentax K-30 & K-50 19 06-02-2013 12:49 PM
K-30 focus screen bcorson Pentax K-30 & K-50 9 02-07-2013 06:52 AM
K-30 focus microadjustment for individual lenses? ChopperCharles Pentax K-30 & K-50 19 07-20-2012 01:57 PM
All times are GMT -7. The time now is 06:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
