Originally posted by rockmaster1964 It will blink if the shutter speed is too slow.
That was my thought after toying with the camera yesterday but, I think it may be tied to the auto ISO setting I was using. Its parameter is set for Standard as opposed to Fast or Slow and so the ISO doesn't increase fast enough to cause the shutter speed to rise above what the camera needs to prevent the flash recommendation. Oddly enough, it doesn't seem to matter when Tv mode is used. You can increase shutter speed to the max of 30 seconds and the camera never recommends the use of flash.
