Originally posted by Jonathan Mac A good charger charges cells individually, so it accounts for the charge level of each cell. When it detects the cell is full, it stops (rather than a cheapie which keeps trying to pump more charge into it), which is extremely important. It allows slow charging, which is better for the battery, but can fast-charge if needed. It discharges a battery before charging again, to stop any memory effect developing which effectively leaves some of the internal chemistry stuck in the charged state and unable to release it's stored charge.
I did my research before purchase and the Sanyo-supplied charger does a slow charge with taper at the end and quits when done. As for "memory", this is a characteristic of NiCd batteries. NiMH batteries do not suffer from this.
As with most things techie, there is always the opportunity to tweak and measurbate. As noted above, there may be some pleasure in seeing the stats. In the case of rechargeable batteries, it is my opinion that the point of diminishing returns comes somewhere before purchase of a charger that costs more than 2x-3x the price of the maximum number of cells it will charge.
With reasonable care using a slow charger a set of Eneloops is good for 1500 cycles/cell. Is the expensive charger able to extend that to 3000?
In other words, will it ever pay for itself?
---------- Post added 02-18-14 at 10:23 AM ----------
Originally posted by Not a Number The chargers that charge only in pairs charge them in series not as individual cells.
My understanding is that the intent is to charge cells together that discharged together. All of my AA and AAA devices use 2 or 4 cells. I purchased the Eneloops specifically for use in my flash (4 cells). As for the colors...I took it as an aid for grouping, not an indication of matched sets.
I suppose I could buy a Maha (or similar), but I have enough hobbies.
