Originally posted by stevebrot Me neither. The little bit of side tension is all it takes to prevent a clean coupling. I consider the grip clearance to be a bit of a design flaw. A millimeter one way or another would correct the issue . Apparently the design teams were not in good communication and/or the QA people were negligent in defining their test cases.
Yes, I think that you are 100% correct here ... just a faction of a millimeter off and it's a problem to couple correctly. Great write up and worth the "like" that I gave it ... Thanks again, and like I said before, wish that I had taken the time to read your review and to think better about this clearance problem before posting ... just in the "bad" habit of going "full blast fast" too often. J
