02-23-2014, 06:27 AM - 1 Like   #16
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by kentishrev Quote
Why would you buy a K-3?
Simply put, it's a great piece of kit.
02-23-2014, 06:47 AM - 1 Like   #17
I would, but then the Daleks would defeat the Gallifreyan Time Lords, creating a temporal paradox that would undo Ricoh.
Wait, what thread was this again?
In all seriousness, I'd be happy with k-30/50/5/ii/s/3. I was happy with my K-x. I'm happy with my k-5ii. What I'm frustrated with is my lack of ability. I'm working on that.
02-23-2014, 09:57 AM - 1 Like   #18
QuoteOriginally posted by dansamy Quote
This is the thread where Tokyo does not get destroyed.
02-23-2014, 10:24 AM - 1 Like   #19
audiobomber's Avatar
I've got the kit 18-55mm, and a 50mm prime. May look at that 50-135, and then think about more primes as I see the lengths I'm using most.
(Later Edit: 1000 for a 50-135 may be out of reach for now! May go for 18-135 first)
I like my 18-135mm a lot, but it wouldn't be my priority. If I were starting out with your kit and budgetary constraints, my next lens would be the HD 55-300mm WR. Actually, that's pretty much the way I got started; 18-55 kit lens, FA 50mm, 55-300, in that order
02-23-2014, 05:01 PM - 1 Like   #20
rfg
OK, this isn't as rude a question as perhaps the title suggests. However, it is a genuine newbie question.
My first Pentax DSLR, as I've mentioned elsewhere, is a K-30. I really enjoy using it, and find it both comfortable and straightforward. It allows me to learn Manual picture taking, and is fine at fairly high ISO when I'm shooting in low light.
Posts I've read are clear, of course, that no camera or lens will make a bad picture good, and ultimate determinant of a good picture is a good photographer. Once that is in place, all posts seem to suggest that it's the lens that makes the difference.
So what is it that makes an upgrade from the lower-end to a high-end so important?
If I owned a K-30 I'm not sure I would upgrade. I bought the K-3 as an upgrade from my K-r. Main features I wanted were (not necessarily in order):
- two e-dials
- pentaprism
- better low ISO
- weather sealing
- (MUCH) better AF
So your k-30 has 4/5 of these already.
camera, k-3, k-30, lens, newbie, pentax help, photography, picture, posts, question, skill
Why did you buy a K-01? slackercruster Pentax Mirrorless Cameras 156 09-28-2013 04:26 PM
Would you buy a Q display model? ChopperCharles Pentax Q 21 12-17-2012 06:52 PM
Wildlife photographers, would you buy a Q sensor... barondla Pentax Q 5 05-01-2012 02:07 PM
Would you upgrade from a K-x to a K-7 or keep the K-x and buy a DA* 50-135mm crossover37 Pentax DSLR Discussion 19 09-11-2010 08:12 AM
Why would you buy a K-x and keep your K200D? mrpackerguy Pentax DSLR Discussion 37 11-17-2009 01:40 PM
All times are GMT -7. The time now is 01:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
