03-01-2014, 08:30 AM   #1
Dropped K5 - F-- Error
Yes, I know I'm not supposed to drop my expensive camera, but I did have an accident.
None of my lenses click into place, so I'm sure that I've damaged something, The question is how bad and what needs to be done.
What should I expect if I send it in to be repaired?
I think I have buyer protection on my Credit Card for accidents like this - that may be the best solution...
Any help or advice would be appreciated.
03-01-2014, 08:43 AM   #2
Emperor and Senpai
VoiceOfReason's Avatar
Can you take a picture of the lens mount so we can see what happened there?
03-01-2014, 08:50 AM   #3
jerryleejr's Avatar
Silly question is your lens set to A?
JJ
03-01-2014, 08:53 AM   #4
If your lens don't click into place more than likely the lens mount flange on the body is bent. Send it in for an estimate. You can pick up a K5 for quite reasonable right now.
03-01-2014, 08:55 AM   #5
jerryleejr's Avatar
QuoteOriginally posted by derekkite Quote
Ironically mines for sale shameless plug...
JJ
03-01-2014, 11:40 AM   #6
johnyates's Avatar
QuoteOriginally posted by Gemvision Quote
By all means take advantage of it. The sooner you send it in, the sooner you'll get it back. Do it today.
03-01-2014, 01:50 PM   #7
Here's the picture. Can anyone see what the problem is?
Any ideas how expensive it might be to fix?
It fell about 4 feet onto concrete - so I'm concerned about all the delicate innards along with the mount issue.
DMC-ZS3  Photo
03-01-2014, 02:17 PM   #8
jerryleejr's Avatar
Well it does look tweaked just looking at the recessed screw heads...I'll send a pic of mine to compare...
JJ
03-01-2014, 02:53 PM   #9
That would be helpful!!!
QuoteOriginally posted by jerryleejr Quote
JJ
03-01-2014, 02:59 PM   #10
jerryleejr's Avatar
Here ya go...
03-01-2014, 03:09 PM   #11
Humm, I may have fixed it. The "F--" error is gone and it is taking pictures again. I suppose some of the innards might still be out of whack. Any ideas about a way to test things out for sure????
I unscrewed the mount and took it off to let the lens fixing pin fit back into the hole. See photo attached. If this thing has had no other "damage" I'm gonna be even more excited about my new camera!!!
DMC-ZS3  Photo
03-01-2014, 03:40 PM   #12
Here are a couple of sample photos taken post - drop using the auto focus. Other than color-balance and exposure setting when I certainly messed-up, I think she'll live to photo another day!
This first shot is focused on the wire - not necessarily my intention - but at least it seems sharp. DFA 100mm Macro.
PENTAX K-5  Photo
PENTAX K-5  Photo
03-01-2014, 03:51 PM   #13
Emperor and Senpai
Yep, looking good. Be careful next time!
03-02-2014, 07:04 AM   #14
JimJohnson's Avatar
I'm slow to the party on this one - when I looked at @Gemvision's first photo of the mount, the first thing I noticed was the locking pin and AF screw were retracted. The MF switch retracts the AF screw, but the only way to retract the locking pin is using the lens release.
The mount is pretty stable - has to be stable - on both the camera and lenses. The fact that it loosened or twisted is not a good sign. It makes me suspicious that the screws are not really holding the mount stable. If you have some form of replacement insurance, it is probably worthwhile to send your camera in for inspection while such insurance is still in force.
03-02-2014, 07:32 AM   #15
QuoteOriginally posted by JimJohnson Quote
Thanks Jim Johnson. I've been wondering about that. Actually, the screw between the locking pin and the red dot is stripped. The rest of the screws are holding fine. I'm also concerned about the weather Resistance. Can they test that the way they test watches????
Where is the best place to send the camera for inspection? How long should I expect the inspection process to take? And do repairs take a long time?
I must admit I'm very impressed with the build quality. I thought the entire camera was history the moment it hit the concrete.
camera, dropped, f--, pentax help, photography
Autofocus Probem/Depleted Battery Error (K5) slowdive101 Pentax K-5 12 10-05-2014 01:17 AM
K5 autofocus error // focus mode: Unknown (272) floriko Pentax K-5 8 11-22-2012 05:19 PM
K5 Memory Card Error WightWalker Pentax K-5 5 11-13-2012 04:04 PM
I dropped my K5 :( Wired Pentax K-5 10 08-25-2012 02:57 PM
Dropped my new K5 on a Samari Sword! SlickYamaha General Talk 6 09-26-2011 08:37 AM
All times are GMT -7. The time now is 10:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
