Updated K5 IIs to v1.07, seems a bug / with video example
* Status screen auto rotate fails to rotate at times and sometimes rotates the wrong way by 180 degrees (IOW upside down). Turning on/off normally fixes it. Taking a picture fixes it.
* Level display same problem, sometimes doesn't rotate with camera, level "sticks" at times (while tilting/rotating camera the level sticks as if if camera isn't being moved). Turning on/off normally fixes it, taking a picture fixes it.
EDIT: start up/wake noise I confirmed is normal, only the screen failing to rotate is a bug.
If anyone can confirm these issues pre or post v1.07 update please chime in, thanks in advance.
link to video:
https://vimeo.com/album/2768614/video/88578709
Thank you,
Roger D
Reason: added link to video
