I had a great theory about what is wrong with your lens, based on a couple of 5omm lenses I've seen: the distance scale glue fail. Here's a photo:
It's a design flaw, the glue barely lasts 50 years.
When this happens, the scale unravels and touches the inside of the ring with the depth of field scale. That scraping noise really sounds like "time for a new lens".
The bad news is, I just took apart my Super-Takumar 135/3.5 and the distance numbers are engraved right into the focus ring, not on a piece that could unravel. Rats, I loved that theory. It still could be true, especially if your lens is the Super-Multi-Coated version. And some construction changes happened on a running basis. You may be able to see whether the distance number scale is part of the focus ring or not.
If you have a tiny straight-blade screwdriver* that fits the three grub screws on the DOF ring, you can test my theory without any other disassembly. Those three screws are 120 degrees apart, to the left and right of the aperture numbers on the scale and one directly opposite the orange dot and line marking the point of focus. The screws have pointed tips and are pinching the DOF scale in place. If you loosen all of them a few turns, the scale can rotate. Now try focusing past 7m. The DOF scale ring might just move along with the focus ring. If you are really lucky, you could rotate the DOF scale ring so the "window" in it allows you to see the seam in the unraveling scale, and glue it back in place. Otherwise the repair means taking off the name ring, filter ring and focus ring, reattaching the scale and reassembly. If you focus the lens to infinity before you start, you can put the focus ring back on in the same spot without resetting infinity focus.
I suppose some debris could have fallen into that same window in the DOF scale ring, causing similar symptoms to a loose distance scale. Rotating the ring like I've described might help you get it out.
Ask me if you have other disassembly questions.
*Eyeglass repair kits often have a screwdriver that fits these screws. The 135 may have straight or JIS screws, possibly both. Some of the screws are way inside, so screwdrivers with thin shafts for about the first 25mm are necessary.
